honda crx B-series swap help
hi i got a 91 crx si and im doing a b-series swap the motor is a 93 acura integra b18A1 cable tranny. And i dont know witch motor mounts to buy because the only ones i see is the b18B1 mounts and i dont know if does will fit can you guys give me some pointers ill gladly accept them.
many companies offer b-series into ed mounts. innovative, hasport, and eBay to name a few.
http://hasport.com/store/index.php/m...s-ef/efb1.html
You will use the Hasport EFB1 mount kit. It is designed to fit all B series with a CABLE transmission like that on the B18A1. You may have to switch out the driver's side engine mount bracket to this one http://www.hamotorsports.com/eflbbracket.html as I beleive the B18A uses a different bracket than the mount kit is made for.
forgot to mention, here is a few other kits you can use
http://www.hamotorsports.com/19150mounts.html
http://www.hamotorsports.com/b19150.html
It will be a million times easier to use the harness that came with the car. It is waaaaay more work to try to make the B18A1 harness to work.
like i said before. it is a million times harder to use a different harness than the one that came with the car. finding a new si harness should not be that hard. i guarantee it will be way easier and less time consuming than attempting to use the del sol harness you have.
hit up Peter at www.rywire.com , bet he has a harness for you or can set you up with one.
mickeywickit
Feb 18, 2015 09:35 PM
