water leakage
Its my experience that 98% of all H20 leaks in hondas can be attributed to the windshield sealing area. Water leaks are easy to find. Hose car with water get a flashlight find it.
We can't tell you that for sure, but as KwayRacing stated, more often than not a water leak in the front of the cabin is usually from the windshield seal. Has the windshield been replaced?
Grab a hose or a sprinkler and soak the car. Make sure you completely dry the area first, that way you are certain if it's leaking again. I would suggest checking the windshield first, but if that's not it, start hosing the car off from bottom to top. You may need to let it soak at each section for a couple of minutes.
Mayorseed
Nov 1, 2007 04:51 AM
crxaddikt
Oct 28, 2002 02:35 PM
