which b16?
Old Mar 29, 2010 | 01:09 PM
b18Aaron's Avatar
Default which b16?
I REALLY want a del sol and after selling my teg im sure i wont get over 2.5k so i wanted to get a single cam sol and swap in a b16 over the summer (im not a professional lol) I do have some experiecne working on motors and hmotorsonline said its a complete change over b with stock motor mounts but i wanted to know if i could put any b16 into a 93-97 sol? And if theres a website with step by step rules can i get the link.
Thanks
Old Mar 29, 2010 | 01:12 PM
Red_Army's Avatar
Default Re: which b16?
you can put any b series into a del sol and it'll mount right up. if you get the full swaps the only thing you might wanna get is a wire harness.
Old Mar 29, 2010 | 01:31 PM
b18Aaron's Avatar
well is a wiring harness the same thing as a engine harness?
here's what the package comes with
B16A 88-91 (SiR I) Complete Change Over
Price: $ 1699.00 Plus shipping and handling.
Availability: Sold Out Till Mid April
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Old Mar 29, 2010 | 01:58 PM
mayrose901's Avatar
that swap is obd0 and you will need an obd1 swap or obd2 if you get a 96-97 if im not mistaken
Old Mar 29, 2010 | 02:03 PM
b18Aaron's Avatar
so if i got a 93 or 94 would it be obd0 or what?
Old Mar 29, 2010 | 02:05 PM
94civiccupew/b7's Avatar
obd1. and you need a hydraulic tranny not cable
Old Mar 29, 2010 | 02:07 PM
get the same obd swap as the car and it will be a straight across swap
Old Mar 29, 2010 | 02:10 PM
b18Aaron's Avatar
So this swap would work?
B16A 92-95 (SiR-II) Complete Change Over
Price: $ 2250.00 Plus shipping and handling
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Old Mar 29, 2010 | 02:13 PM
mayrose901's Avatar
as long as you get a 93-95 del sol. 88-91 are obd0. 92-95 are obd1. and obd2 are 96+
Old Mar 29, 2010 | 02:28 PM
egsleepercivic's Avatar
you want the SIRII swap with the hydro tranny, also you will use the stock harness and add wires as needed
here is what you need also you need to tell them you are putting it in a del sol so they can give you the right shift linkage
http://hmotorsonline.com/shop/sc2000...age&item=30005
Old Mar 29, 2010 | 02:30 PM
and pay the extra $300 for the lsd tranny. it's worth it. otherwise you'll want it down the road and end up paying $1000 to buy and install the lsd. just my 2 cents
Old Mar 29, 2010 | 06:51 PM
b18Aaron's Avatar
what does the lsd tranny do? or how does it help?
Old Mar 30, 2010 | 09:24 AM
Red_Army's Avatar
instead of one wheel drive wheel burnouts you can do two wheel burnouts.
better traction. it picks a wheel with less power and gives it more while still giving the other tire some too. or it picks the better gripping wheel i can't remember off the top of my head.
but i have a 95 DS with the SIR II and lsd and its good fun. no b18 but still fun.
Andyxramirez
20
Mar 28, 2013 02:23 PM
gzes
25
Dec 19, 2012 05:46 AM
Chyno
14
Oct 15, 2007 09:34 AM
brandonejoos
Mar 14, 2007 08:15 PM
LbcJiGGa
Mar 18, 2003 06:14 AM
