Misfire Under Acceleration, Poor Acceleration
Old Mar 28, 2010 | 07:57 AM
Unluckyhonda's Avatar
Icon6 Misfire Under Acceleration, Poor Acceleration
The other night i was driving home and my car started misfiring, and i was not able to accelerate worth a crap, felt like 50% power loss. Pulled over and the converter is BRIGHT RED and smoking, so i pulled into my friends house shut it off. Let it sit overnight to cool down, checked the plugs, wires, cap, rotor (did tune up last year) and cylinder one was fouled out bad, cap and rotor had corrosion build up, so install new cap, rotor, 4 new spark plugs (NGK V-Power) and car starts and acceleration seems to have picked up but its no where near 100% and im getting a slight misfire under acceleration, (thats probably my cause for not feeling 100% power output) but, im stumped i have a test pipe arriving on monday or tuesday and im going to yank the converter out and install that (im not saying thats going to help) But all this has been happening out of no where all of a sudden and worse thing about it NO CHECK ENGINE light at all (yes it works) Im at a loss of what to do, a friend suggested replace the coil in the distributor idk can anyone help out or maybe had this situation. Thanks
Car: 2000 Civic Si
Engine: JDM B18C (GSR)
ECU: Stock OBD2 USDM GSR
Old Mar 28, 2010 | 08:15 AM
Anon51's Avatar
Default Re: Misfire Under Acceleration, Poor Acceleration
maybe an injector failing or clogged up or stuck open.
Old Mar 28, 2010 | 08:17 AM
Can i somehow test that?
Old Mar 28, 2010 | 10:54 AM
92shade's Avatar
your cat could be clogged and restricting air flow. this would also cause it to be bright red.
Old Mar 29, 2010 | 07:22 AM
TurboTron's Avatar
shitty fuel filter/running too rich?
Old Mar 29, 2010 | 07:42 AM
Jockone's Avatar
Did you check plug wires?
Old Mar 29, 2010 | 04:42 PM
replaced fuel filter 1 1/2 ago, and wires are new from last year.
Old Mar 29, 2010 | 05:59 PM
Jockone's Avatar
Get spray bottle with water in it and spray down wires and dizzy well then inside dark garage or at night get someone you trust well inside the car,start it up and look for sparks.Might have to load the engine a bit.
Old Apr 2, 2010 | 05:09 AM
Well new distributor didnt fix the problem, installed new fuel pump, didnt fix the problem, removed the converter installed a test pipe, didnt fix the problem, nothing is arking, timing is on, compression is good, resistance in the wires is good, nothing is fixing the problem.... idk what to do anymore.
Old Apr 2, 2010 | 05:35 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Wait a minute.
You're running a stock GSR ECU on a B16, and you're getting NO CELs? Something strange is going on. A stock GSR ECU should throw a CEL on a B16.
And you said you replaced the distributor? Wanted to verify because I chased no CEL misfire problems on my B20z for a long time, and it turned out to be the distributor.
Is your new test pipe overheating like your cat was? If everything that you checked is truly good, I'm starting to think maybe you have a bad TPS or something.
Old Apr 2, 2010 | 05:54 AM
TurboTron's Avatar
a bad TPS would not cause misfire or such a drop in power....I'm boggled by your problem dude.
Old Apr 2, 2010 | 08:44 AM
yeah, but I'm wondering if it's not necessarily misfiring, but maybe bogging because of leaning out. Or maybe knock sensor's retarding timing for some reason. Or a possible wiring or ground problem. Or something. I'm kinda grasping at straws, but if he's replaced the whole ignition system including distributor and has good compression, then I can't see how it's misfiring at all.
I still think he needs to start by getting the right ECU for that car though. There's definitely something wrong if he's getting no CELs on an OBD2 P72 ECU on an OBD2 B16. It should at the very least throw a light for IABs on that engine unless it's been reprogrammed.
OP: Do you have the original ECU? I think it should be a P2T, right? If so, I'd plug it in and see what happens. Have you tried scanning for codes even though the CEL's not on?
Old Apr 2, 2010 | 01:52 PM
Icon3 Re: Misfire Under Acceleration, Poor Acceleration
Originally Posted by Unluckyhonda
Car: 2000 Civic Si
I am not running a b16 i have a b18c with the usdm ecu for that engine, i have not replaced the wires (this year) but was told theres a high chance that is the problem and there arking on the spark plug tube wall, im going to try that and see what happens i will keep everyone posted thanks for trying to help me out, i really appreciate it.
Old Apr 3, 2010 | 04:48 AM
well last night i decided to replace the spark plugs and it breathed life back into the engine, i drove it for 100 miles and its back to how it should be, i cant believe i overlooked something so small, and i guess lession learned if theres ever a misfire always start with cap, rotor, plugs, WIRES! Just because it passed the resistance check means nothing well thanks for the info and help guys i really appreciate it.
shadysslim
Engine Management and Tuning
Apr 22, 2013 08:46 AM
Phat Corolla
Jan 2, 2005 10:30 PM
moon1961
May 30, 2004 11:34 AM
Kamin
Jul 31, 2003 07:45 AM
HavokB18
17
Apr 21, 2003 03:44 PM
