Turbo B16: Normal coolant and IAT temp?
Old Mar 26, 2010 | 03:49 PM
velisma's Avatar
Default Turbo B16: Normal coolant and IAT temp?
I have a stock dual core radiator on a bone stock B16A w/ a Garret 57trim/63 A/R and did a few pulls while datalogging on my S300. I got a boost cut & a CEL because my engine was beginning to overheat a little (never went past the middle section) after boosting about 3.5psi and today was a bit on the warm side. My question is this... what is considered the normal water (coolant) and Intake operating temperature on a B16A? My display indicated while cruising that my water temp was at 202* and after doing about 3 or 4 pulls it went up to 208*. My downpipe is close to my radiator and I'll be wrapping it tonight or tomorrow sometime. I also have my license plate on the middle of the bumper too. Could that be contributing to this? Is this what everyone calls "heat soak"? This is my first boosted car so I'm learning...
Old Mar 27, 2010 | 09:52 AM
velisma's Avatar
Default Re: Turbo B16: Normal coolant and IAT temp?
bump for an answer
Old Mar 27, 2010 | 12:26 PM
velisma's Avatar
TTT
Old Mar 28, 2010 | 03:06 AM
david974's Avatar
get mugen thermo fan switch and Mugen thermostat install them and set you fan sooner in Hondata
http://www.xenocron.com/mugen-thermostat-p-273.html
http://www.xenocron.com/mugen-thermo...tch-p-274.html
also check you base timing too much timing can over heat your car
Old Mar 28, 2010 | 03:43 AM
lyncoors's Avatar
holy crap a $90 thermostat
linkdeezie
May 14, 2019 11:49 AM
00trdtaco
Sep 3, 2009 09:06 PM
M2B4
Apr 20, 2006 09:56 AM
twenty
Jul 21, 2005 08:36 AM
dkdjlf
Aug 14, 2003 10:34 AM
