Need Help Identifying Turbo
Old Mar 26, 2010 | 08:12 AM
kte324's Avatar
Default Need Help Identifying Turbo
I would like to know what size restrictor to use and what downpipe flange I would need so I can get the exhaust shop to make me a custom downpipe. Let me know if you need more pictures or information.
Old Mar 26, 2010 | 11:29 AM
timmy tegra's Avatar
Default Re: Need Help Identifying Turbo
Do you know the a/r sizes of the compressor side and exhaust side. If the turbo isnt ball bearing there really is no use for a restrictor, and you will need a 5 bold exhaust flange. Hope that helps you out.
Old Mar 26, 2010 | 04:32 PM
velisma's Avatar
I had the same question regarding my Garrett .57trim and posted this thread not too long ago>>>>
https://honda-tech.com/forums/forced-induction-16/oil-restrictor-yes-no-2730302/
As you'll notice, there are ALOT of different, good opinions from some people on HT that know there stuff. I run a .065 restrict-or flange on my btw... GOOD LUCK!!!
Old Mar 26, 2010 | 05:50 PM
rat city rex's Avatar
Run a restrictor. You will need one. Turbos only need around 10 psi of oil press. Now think if you ran 70+ lbs of psi what it would do? It will push past your oil contole rings and it will then smoke.
Old Mar 26, 2010 | 07:48 PM
91jdmhatchback's Avatar
that looks like the larger ford style 5 bolt dp pattern.
Old Mar 29, 2010 | 04:20 AM
kte324's Avatar
The exhaust is a .48a/r and the intake is a .42a/r.
Well I decided to use a .060 restrictor, now I am just trying to find a downpipe flange. The normal t3 five bolt flange just doesn't line up.
O16581724 5 2 5
Jan 17, 2006 08:06 AM
crex23
Dec 11, 2004 06:01 AM
Neukin
Aug 16, 2004 04:47 PM
