How does exhaust attach to this?...
Old Jan 16, 2006 | 06:28 PM
O16581724 5 2 5's Avatar
Default How does exhaust attach to this?...
Old Jan 16, 2006 | 06:57 PM
Everyones Hero's Avatar
Default Re: How does exhaust attach to this?... (O16581724 5 2 5)
The part with the two holes in the top connects to your turbo manifold and the downpipe should connect to the hole on the right side of the turbo.
Where'd you get that? Looks like a T4 exhaust flange.
Old Jan 16, 2006 | 07:14 PM
Default Re: How does exhaust attach to this?... (Everyones Hero)
Let me get another angle of where the downpipe connects.
Old Jan 16, 2006 | 07:40 PM
crxnj's Avatar
Looks like you need some kind of v-band clamp..I've never seen that style before,what kind of turbo is that?
Old Jan 16, 2006 | 07:46 PM
Default Re: How does exhaust attach to this?... (Mr.speaker)
Holset, but there's no place for a V-band. I guess i'll weld a V-band to it or something.
Old Jan 16, 2006 | 08:39 PM
lucidvtec's Avatar
i heard u need some JB weld for that...
lol
Old Jan 16, 2006 | 08:57 PM
Default Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">i heard u need some JB weld for that...
lol</TD></TR></TABLE>
JB Weld is overrated.
Old Jan 16, 2006 | 09:11 PM
Hulk22's Avatar
email holset give them all the numbers and then ask them to cross ref. for a exth. housing that will fit. good luck spoolin it get some juice for it!
Old Jan 16, 2006 | 09:31 PM
.RTErnie's Avatar
Default Re: (Hulk22)
why dont you just buy a real turbo and stop picking up these junkers.
GARRETT&lt;-- 550 shipped all day long from Phil aka Sp00lin
Old Jan 16, 2006 | 09:42 PM
Default Re: (~RTErnie~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~RTErnie~ &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just buy a real turbo and stop picking up these junkers.
GARRETT&lt;-- 550 shipped all day long from Phil aka Sp00lin</TD></TR></TABLE>
Because i've spent less than that on used ones that have only failed due to my error, too much feed, too much restriction (nitrous restrictor clogged), bad drain...
I don't see ruining a new turbo through trial and error.
As far as spooling it, expletive it, it's cheap, if it doesn't spool, i'll resell it for more than i paid for it.
Old Jan 16, 2006 | 09:46 PM
Dmc1's Avatar
I looks like thier may be bolts that are snapped of and rusted over in some of those six tabs surounding the discharge?? maybe? it had to connect to the downpipe somehow the two at 8 and 10 oclock really look like they have old snapped of bolts in them...I'd say get another turbo if you can.But I know how it is you have to use what you have sometimes.
Old Jan 16, 2006 | 09:57 PM
Default Re: How does exhaust attach to this?... (Dmc1)
I haven't actually bought this turbo yet, but it's available to me dirt cheap and if anything, i have a welder so i can put a V-band on it. I'll get ahold of Holset, i can't believe i didn't think of something so obvious.
Old Jan 17, 2006 | 01:09 AM
rudebwoy's Avatar
let me guess! magnetic flange?
Old Jan 17, 2006 | 01:14 AM
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">let me guess! magnetic flange?</TD></TR></TABLE>
Haha, i don't know, maybe someone sees or knows something i don't.
Old Jan 17, 2006 | 04:35 AM
nsxmatt's Avatar
Amen. You could buy a decent used turbo for $300-400 and your trying to make farm tractor turbos work to save a few bucks.
Old Jan 17, 2006 | 06:27 AM
Joseph Davis's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
Amen. You could buy a decent used turbo for $300-400 and your trying to make farm tractor turbos work to save a few bucks.</TD></TR></TABLE>
If the turbo in question were a little cleaner, I'd disagree with you...
Old Jan 17, 2006 | 06:29 AM
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">If the turbo in question were a little cleaner, I'd disagree with you...</TD></TR></TABLE>
Hell, a little sandpaper and parts cleaner and it'll be good to go.
Clean it up and make a flange for it. Weld the flange onto the exhaust side and make a downpipe.
How does the turbine spin? Any shaft play? Rough at all?
Old Jan 17, 2006 | 06:37 AM
splitime's Avatar
I'm guessing its a slip fit.... I'm also going to suggest that you just get a Vband welded to it and call it a day.
Old Jan 17, 2006 | 06:40 AM
Brain3208's Avatar
Default Re: (Everyones Hero)
From the size of the inner lip near the wheel i would think you could easily find a pipe that would slip inside the hole and then weld it with a V-band on the End.
brain
Old Jan 17, 2006 | 06:43 AM
TheShodan's Avatar
Moderator
TIG welding to a Nickel Iron like that isn't going to work very well at all. It could also that the metal is contaminated so the weld won't hold.
This looks like a slip fit w/ 6 bolt patter similar to Garrett's Internally gated GT32 (in its original form.)
I Guess I'm in agreement with others, this is much more trouble than its worth.
Old Jan 17, 2006 | 07:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">
Hell, a little sandpaper and parts cleaner and it'll be good to go.</TD></TR></TABLE>
Most everything I've laid hands on where the turbine housing rust had advanced into scaling, and had a bunch of ignorant overspray from John Deere, Jr, trying to fix up his **** so it would look ghetto bling... yeah, needs a rebuild.
It may be worth fooling around with, but you need to find out what you have in the first place. Compressor capacity, turbine cm^2, etc.
Old Jan 17, 2006 | 08:00 AM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">Let me get another angle of where the downpipe connects.
tap those bolt bosses for whatever hardened bolt you want and then have a mild steel flange milled to match that outlet and voila, you're done.
Old Jan 17, 2006 | 08:06 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: How does exhaust attach to this?... (stackz)
you can pull the housings off and have them media blasted ( i can do it) and it will look good as new
stackz
Welding / Fabrication
Feb 2, 2007 07:05 AM
f1 vtec
Aug 21, 2004 08:52 AM
Neukin
Aug 16, 2004 04:47 PM
