Goal 650whp. Will my setup work? Input Please
Old Oct 21, 2009 | 07:19 PM
kte324's Avatar
Default Goal 650whp. Will my setup work? Input Please
** 507 on 93 at 20psi & 586 on C16 (Boost went up and down)
I have been gathering parts and working on this project for about a year now and I am finally ready to put all this together. Here is a list of everything I have now. My goals are for 650whp and low 10's at the track. This setup will be in a eg hatch with no interior.
Engine:
84mm Benson sleeved B16
Pauter Rods
Cp 9:1 Pistons
B16 head
Skunk2 pro springs, retainers, and tuner1 cams
Ferrea valves
Victor X mani w/ Omni 70mm TB
Omni 5bar map
Oem new crank pulley
Transmission:
Gsr, stock gears and FD
Mfactory lsd
Comp twin
Stock axles
Turbo Setup:
.70a/r t3 s362
Neukin topmount w/ 4" dp
44mm Tial wastegate
Tial BOV
600hp precision IC
2.5" hotside ic piping
3" Coldside piping
Fuel System/Ignition/Ecu:
ID1000cc
Twin Bosch 044
AEM rail
Fuel Lab FPR
-8an feed, -6an return
Stock w/ external msd coil
Hondata s300 w/ boost by gear
Please give me some opinions on my setup or if I need to change anything to reach my goals. Thanks.
Old Oct 21, 2009 | 07:52 PM
mikebranson's Avatar
Default Re: Goal 650whp. Will my setup work? Input Please
Very similar to a build i'm working on as well. GL.
I would check with your tuner on the single Walbro....
I'm not sure thats gonna give you the FP you need for 30psi to make your 650.
Everything else looks solid as long as you load those axles before you launch
Old Oct 21, 2009 | 08:19 PM
sabrosa489's Avatar
Engine:
Pauter Rods
Cp 9:1 Pistons
B16 head
Skunk2 springs, retainers, and tuner1 cams
Ferrea valves
Victor X mani w/ stock 62mm tb (should I upgrade 70mm?)
thinking about ati or fluidampr
Transmission:
Mfactory lsd
Comp twin
Stock axles for now.
Turbo Setup:
.70a/r t3 s362
44mm wastegate
600hp precision IC
2.5 ic piping(might upgrade to 3" cold if I upgrade tb)
Rc 1000cc
Walbro 255 intank
Bosch 044 inline
AEM rail & regulator
-8an feed, stock return
Tuner = Mase
awesome set-up dont worry about the 62mm tb turbo cars push the air in dont suck-it in... any way the only thing i will add up will be in line fuel pump with a Y to that -8an feed. To make sure you have more than pleanty of fuel for the hungry 1000cc injectors an reach the power goals
Old Oct 21, 2009 | 09:44 PM
whiskaz's Avatar
you have the same exact setup as i do except i have 83mm 10.1cr pistons.
i made 670hp.
http://kcsr.org/showthread.php?t=34345
Old Oct 21, 2009 | 10:05 PM
dancing_ninja's Avatar
Sounds like a really nice set up!
You my consider doing 83mm pistons just as a precaution.
I would say, Axles are definitely gonna have to be upgraded.
Especially if you are going to use slicks or drags rads. Also, Injector Dynamics injectors are the $h!t. RC's aren't bad, I'm just saying. I'm assuming you're going to use the big AEM 1:1 regulator.
I like the ATI dampers. They are really nice. I wouldn't skimp on the tb.
Best of luck!
Old Oct 22, 2009 | 08:17 AM
kte324's Avatar
i made 670hp.
Wow that's exactly the power I am looking for. How many psi was that?
For the other posts: The engine is already built so I can't change the 84mm and I am using a Bosch 044 inline and Walbro intank as stated above.
Old Oct 22, 2009 | 08:33 AM
tuan_turbo_dc4's Avatar
What gas will you be using?? With a 1000ccs race gas Vp Q16 will get your power goals.
Anything else you might not hit it.
I would ditch the msd external coil and going with tony t1's m&w ignition setup. With that much hp, you need some reliable ignition on the top end.
Definately some upgraded axles would not hurt. Going 10's with some stock axles will be a challenge.
Other than that, I'm sure Mase will do his magic and you should hit your goals.
Old Oct 22, 2009 | 08:49 AM
DA TeG 90's Avatar
Great set up. You will make 600 no problem.
i would pick up a 70mm throttle body. I just picked up a Omni Power 70mm TB for 99 shipped..check out the market place under FI.
Old Oct 22, 2009 | 09:46 AM
1badascivic's Avatar
X2
Old Oct 22, 2009 | 09:52 AM
whiskaz's Avatar
logs showed 29.2lbs
Old Oct 22, 2009 | 10:32 AM
kte324's Avatar
It will be one C16, and the axles will be upgraded when I hit the track. DSS 3.9
Yeah, I saw it on there, thats what gave me the idea. I think I might get one.
Old Oct 22, 2009 | 11:13 AM
DA TeG 90's Avatar
You will be able to get into the mid 9's with 650whp I think.
Old Oct 23, 2009 | 09:25 PM
kte324's Avatar
Hopefully my fuel setup will make it.
Old Oct 23, 2009 | 11:15 PM
boxeocampeon's Avatar
your gonna need a good as tune
Old Oct 24, 2009 | 06:17 AM
sweetfwdthunder's Avatar
I think your setup looks good, but i would definitely go with the ID1000's rather than the RC's. You have all you need for fuel pumps, and if needed with the id1000's you can just turn up the pressure and have bigger injectors Either way, I think you'll hit your goal
Old Oct 24, 2009 | 04:14 PM
kte324's Avatar
Depends on how the money looks I might get some ID1000s.
Old Oct 27, 2009 | 05:50 AM
Topdawgg's Avatar
ive got a similar setup, but im using the Full blown dual walbro setup.
I have 1000 RC's right now, im wondering if I should go with 12/1600s and an injector driver. OR should I pick up the ID1000's as well?
Old Oct 27, 2009 | 11:15 AM
I would go with the IDs. They are the bomb!.... I mean, I like them a lot. lol
Old Oct 27, 2009 | 12:19 PM
Topdawgg's Avatar
Im just wondering if I should step up to the ID2000's or stick with the 1000
Old Oct 27, 2009 | 02:59 PM
2.0 and up's Avatar
i would def go with a 70mm tb and some id injectors(1000's)! looks like a good build, hope everything turns out good!
Old Oct 28, 2009 | 06:29 PM
kte324's Avatar
Is there anything else I should do to my ignition?
Old Nov 4, 2009 | 11:22 AM
KTULU990's Avatar
Very nice setup!
It's very close to what i'm doing except I have a H22. I have the same power goals.
Right now I have a single Bosch 044 inline w/ id1000's... From what you are saying I would need another fuel pump as well?
What should I go with? another Bosch 044 inline?
Old Nov 5, 2009 | 04:00 AM
kte324's Avatar
Originally Posted by KTULU990
Very nice setup!
I am not sure, you are using id1000's which are really good injectors. You would have to ask someone with id1000's. If it were me I would add another fuel pump for reassurance.
Old Nov 5, 2009 | 01:29 PM
Turbo-LS's Avatar
if you have the funds then get your self an M&W pro-10 if funds are low you can always run something liek a mallory or summit ignition box with a msd coil. they have been proven to work better than stock but not as good as a M&W
Old Nov 6, 2009 | 06:16 AM
Topdawgg's Avatar
im running the dual walbro Full blown setup and was talking to tony1 about the ID1000's for my goal of 650 range and he said they will be perfect... he said they would make that no problem.
