tuning and basemaps stock b20b turbo obd1
idk if this the right place to post this but i tried google and xenocrons website and even pgmfi.org and i got no help
ive converted to obd1 in my da after recently leaving turboedit for chrome
or whatever i could get my hands on 1st anyway i cant seem to find a b20b turbo basemap
here are my specs
stock b20b non vtec
dsm 450cc injectors
motorola 2.5bar map
t3/4 turbo
walbro 255 lph
if theres a premade tune or a good basemap my car is a daily and i need to get it on the street asap.....any help would be appriciated
thanks HT
here are my specs
stock b20b non vtec
dsm 450cc injectors
motorola 2.5bar map
t3/4 turbo
walbro 255 lph
thanks HT
http://www.xenocron.com/install/CromeGuide.htm
This should give you a general idea of how to create a basemap. If I remember right Crome has an option where you can change your liter to a 2.0 as well.
Don't use an existing map, that's a good way to roast an engine.
Start with the stock B20B map from PGMFI's ROM directory and all you'll really need to do is run boost & fuel tools, then maybe adjust your battery offset in the advanced tables.
Keep your timing conservative until you hit the dyno, especially in the upper right section.
i dont plan to touch my timing...as of right now!...... i just need to get my afr's right but crome looks like a bunch of blah blah blah to me! right now im running stoopid rich and the car is just parked.....is there a writeup for a streettune for crome???
I already posted this before but then again if you dont understand it then you wont understand it. I had my brother in law show me, that was the only way I figured it out.
you change the afr by editing the numbers in the cells of the map. honestly you need to have any experienced tuner tune the car. you absolutely should not be boosting on just a basemap. use the basemap to drive safely to the tuner and let them take care of the rest
okay i know that im am NOT trying to boost with the basemap........the basemap that was provided with my ecu was not the type of basemap that i wanted to run on my car the ignition was wayyyy to high before and into boost! the reason why im asking is because i tuned my car on turboedit .....then i jumped on over into obd1 and i have a basic idea on crome but its not allowing me to set up a terget afr
birdman1424
Jun 27, 2007 12:44 PM
