ECU got wet while driving, spark but no fuel
Old Mar 23, 2010 | 04:42 AM
EdSales's Avatar
Default ECU got wet while driving, spark but no fuel
About 6 months ago, I creamed a Deer on the passender front fender of my EG6. I replaced all body parts and hammered the apron back into place. However, while driving down 95 in the pouring rain, my car shut off. I began doing my checks. Jumped the ECU for Codes and all I got was the Solid CEL. Checked the ECU and it was soaking wet. Appears I have a crack somewhere in my firewall or floor board perhaps.
Anyways, its a P30 ECU with Hondata S-300. I let it dry for a day and tried to start it. I got spark but no Fuel. Fuel Pump is not priming either. I did not have the time to check fuses yet. I plan on spending all day Thursday working on it.
I'll be replacing any blown fuses and my Main Relay, but is there any chance my ECU could be dead?
Old Mar 23, 2010 | 07:06 AM
dmeconitas's Avatar
Default Re: ECU got wet while driving, spark but no fuel
Usually a solid cel light indicates a dead ecu. Besides the main relay the ecu controls fuel and that is probably why you are getting no fule.
Old Mar 23, 2010 | 08:13 AM
EdSales's Avatar
Would the water kill my ECU like that? Could it just be that the fuse under the hood is dead?
Old Mar 23, 2010 | 08:16 AM
Deetz's Avatar
Crazy Honda Guy
YES!!! water and circuit boards do NOT mix!!! This should not surprise you, especially if it was soaking wet!
Old Mar 23, 2010 | 08:24 AM
EdSales's Avatar
You think the Hondata would have survivied?
Old Mar 23, 2010 | 08:56 AM
EdSales's Avatar
Or is there a way to check if the Hondata is good? The RED Light lites up on it.
Old Mar 23, 2010 | 09:13 AM
95BoostedEJ1's Avatar
im gonna say u fried the ecu..and if the hondata was beside the ecu and was wet then it prolly fried the blue box as well..but you might get lucky and beable to save the box and just replace the ecu
Old Mar 23, 2010 | 09:41 AM
EdSales's Avatar
S200 is in the Blue Box, I got the S300J which is chipped inside the ECU. Is there any way I can test the Chip to check if its still good? The Red Lite still lites up on it.
K i l l a B e e.
11
Sep 1, 2008 01:08 AM
kasso
Feb 17, 2006 07:57 AM
bub838
Apr 22, 2004 08:03 PM
hybridb18
Apr 9, 2004 04:09 AM
