Where am i leaking from ???
Old Mar 22, 2010 | 10:47 AM
T Thrash 09's Avatar
Default Where am i leaking from ???
ok so i have a 95 civic d16z6 and it leaves a good sized puddle every time i park for like an hour or so. I have replaced the oil pan gasket and the rear main seal . Now for some info there is oil on my tranny dripping on my exhaust and on my oil pan so what do you guys think ?
Old Mar 22, 2010 | 10:59 AM
Ruben19's Avatar
Default Re: Where am i leaking from ???
pictures?
get it fix asap
Old Mar 22, 2010 | 11:07 AM
Linked's Avatar
check the top of the engine, sohc's notoriously leak oil from the distributor o-ring
JKov240's Avatar
Perhaps the large o-ring behind the oil filter? (Not on the filter itself, the housing the filter screws to has an o-ring)
Clean it all off, drive it for a bit and see if you can locate the source.
Old Mar 22, 2010 | 11:58 AM
96hb's Avatar
Check your distributor o-ring and your valve cover gasket.
Old Mar 22, 2010 | 12:41 PM
delsolo95's Avatar
Ever checked the trasmission seals?? v-tec solenoid, dizzy O ring... most common
Old Mar 22, 2010 | 12:46 PM
kaiba's Avatar
Drain plug crusher washer?
Old Mar 22, 2010 | 01:51 PM
4g4dcruisin's Avatar
He said drips onto the oil pan...
have you checked your head gasket?
Old Mar 23, 2010 | 09:14 AM
i believe i found out what it is i put my hand under the vtec solinoid and it was dripping oil so im guessing its the gasket
Old Mar 23, 2010 | 09:36 AM
Dealer only item, autozone, kragen, pepboys, napa had no clue what i meant by, "vtec solenoid gasket".
Old Mar 24, 2010 | 05:25 AM
yup called all theses places and they were like theres nop such thing are you sure thats the name. how much did you pay for it at the dealer?
Old Mar 24, 2010 | 05:26 AM
yup called all theses places and they were like theres nope such thing are you sure thats the name. how much did you pay for it at the dealer?
Old Mar 24, 2010 | 06:39 AM
Around $15 or so. Its the dealer, they always rape you.
Old Mar 25, 2010 | 05:31 AM
dvd5904's Avatar
I had the same issue with mine. You might as well replace the oil pressure switch gasket (another dealer item) while you're working on the VTEC solenoid. It is mounted on top of the solenoid.
JDMob
Jan 26, 2020 11:17 AM
blacktibby07
21
Feb 3, 2011 04:42 AM
davey5300
May 7, 2010 06:01 PM
granny racer
Sep 22, 2009 01:17 PM
MeanGreenEG9
Jan 13, 2003 11:09 AM
