Integra Rear End Question
Old Mar 18, 2010 | 09:43 AM
nothing_shocking's Avatar
Default Integra Rear End Question
I already have this done (92 Si) but I need new calipers. I have a brand new set of 92 Teg LS calipers, but I'm not sure if those will fit on the 3rd gen teg rear. So do they? If not, could I use the trailing arms and stuff off the 92 LS to make them work?
Old Mar 18, 2010 | 11:22 AM
itsnotfast's Avatar
Default Re: Integra Rear End Question
I could be wrong, but i'm pretty sure they're different. The DA will not work, you need DC trailing arms and calipers.
Old Mar 18, 2010 | 08:25 PM
So the DA trailing arms won't bolt on?
Old Mar 19, 2010 | 01:21 PM
anyone?
Old Mar 19, 2010 | 01:53 PM
itsnotfast's Avatar
I don't think so.
Old Mar 19, 2010 | 02:16 PM
DCRB's Avatar
i'm using dc2 calipers on my da rear trailing arms. they're the same
Old Mar 24, 2010 | 07:41 PM
Did you have to use different brake lines or anything? Also, I found that the trailing arm bushings are the same and the rotors are the same but the trailing arms between the DA and DC are different...
Old Mar 24, 2010 | 08:39 PM
EL Vap133's Avatar
The only major diffidence between the both are the RTA bushings, they are virtually the same!
pablopab50
Suspension & Brakes
Aug 21, 2013 08:47 PM
asianflava
Dec 8, 2008 11:14 AM
drew2
13
Jul 27, 2006 07:50 AM
Natural Aspirations
Jul 14, 2004 11:46 AM
handiman15
26
Apr 13, 2002 01:11 AM
