Suspension & Brakes Theory, alignment, spring rates....
ground control coilovers adjustments
Old Mar 16, 2010 | 10:15 PM
phrack3r's Avatar
Default ground control coilovers adjustments
i cant seem to adjust the fronts of my koni/gc setup cause the sleeve will spin with the adjuster. how can i keep the sleeve from spinning? ive tried use vice grips and a towel in between but it wont help, thanks.
Old Mar 16, 2010 | 10:30 PM
STOCK_SOHC_DX's Avatar
Default Re: ground control coilovers adjustments
strap wrench?
Old Mar 17, 2010 | 03:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Get a rubber strap wrench to hold the sleeve in place. You did loosen the allen screw first, right?
I had the same issue when I had GC's so I wrapped one layer of electrical tape around the shock body to keep the sleeve from spinning. It was a PITA to get the sleeves on, but it worked. Later it was even more of a PITA getting the sleeves off when I sold the GC's.
Click the link in my sig to see pics.
Old Mar 17, 2010 | 11:29 AM
mkazm83's Avatar
I can stop the sleve from spinning with my hand.
I did the tape thing on the fronts as Patrick suggested, and it worked fine.
Kind of wish I didn't because when I want to fine tune it, I have to pull off some acrobatics to get the allen wrench into the collar.
Old Mar 17, 2010 | 11:38 AM
SoTexDC2's Avatar
Clean the GC sleeve and spray some WD-40 on the threads. Tap the perch with a mallet to help break it loose. You should be able to hold the sleeve in place with your hand. And as said above, be sure you have loosened the pinch bolt enough.
Old Mar 17, 2010 | 12:34 PM
Community Builder
Sometimes if the sleeve gets dirty, it can be very hard to get the perch to turn freely just with your one hand while the other one holds the sleeve in place.
I never bothered with fine tuning the height of mine more than full turn increments. I always had the perches set to where the allen bolt was more accessible.
Old Apr 16, 2010 | 02:47 PM
NyPosterBoy's Avatar
I'm having the same issue. But unfortunately the coilovers are already installed. I hope I wont have to take them off just bc of that
Old Apr 17, 2010 | 06:01 AM
Old Apr 21, 2010 | 04:12 PM
Cynical 1's Avatar
clean the threads, and apply some anti-sieze to them. make sure it works into the threads behind the adjustment perch as well.
i do this with all my gc's (have several sets on various cars) and have never had one get stuck or bound up.
datssoled
Suspension & Brakes
Jun 27, 2007 07:25 AM
Integra187
Jan 13, 2005 08:07 AM
Integra187
May 12, 2002 07:58 AM
AllMotorITR
Dec 13, 2001 06:37 PM
keys
Jul 21, 2001 08:31 AM
