No boost
Old Mar 16, 2010 | 12:16 PM
TheOdd001's Avatar
Default No boost
Just got done installing turbo and wired in a wideband sensor with gauge and boost gauge. I have an intercooler, Turbonetics Raptor BOV and Turbonetics Wastegate. I also have an S300 and can watch the MAP.
I started the car and revved it. I can see that the MAP never goes into positive pressure and the boost gauge coincides with my stock MAP sensor. I never go into boost and the BOV opens up and gives a loud woosh when I come off the throttle.
Any thoughts on why im not boosting?
Old Mar 16, 2010 | 12:25 PM
turbo gsr2000's Avatar
Default Re: No boost
u may have a leak on u i.c pipe go over it real good <<<
Old Mar 16, 2010 | 12:43 PM
turbodano's Avatar
Yes check that you have all your intercooler pipes connected and also that you installed the wastegate seat for your wastegate. It is also called a fire ring.
Old Mar 16, 2010 | 12:59 PM
TheOdd001's Avatar
I have checked the IC piping and I have an Evolution Wastegate, I don't think it has a "fire ring"
Old Mar 16, 2010 | 02:54 PM
street_ride14's Avatar
You have to have load on the engine in order to go into boost, this wouldn't happen in Neutral, you would actually have to be moving in gear before you hit any positive boost.
rat city rex's Avatar
Have you tried driving it yet to see if it goes into boost? Or are you just sitting in the driveway reving it up? Most cars WONT build boost just sitting there. You have to put a load on it to build boost.
Old Mar 17, 2010 | 01:13 AM
TheOdd001's Avatar
What? Really? No I haven't taken it for a test drive at all yet... I'm afraid to till I know I can control the boost level...
Old Mar 17, 2010 | 04:26 AM
kyden's Avatar
you're not gonna get any boost without driving it.
Old Mar 17, 2010 | 05:07 AM
dpetro1's Avatar
i would suggest you do not drive it until you are getting tuned. boosting on an untuned setup can be dangerous.
your boost level will be controlled by the wastegate and can be adjusted via boost controller. again i wouldnt mess with it until being tuned.
keith98
Jun 11, 2006 11:21 AM
red cx
Jul 25, 2003 10:07 AM
johnisenglish
Jan 24, 2003 08:18 AM
ion_four
Aug 12, 2002 07:59 AM
H23ludedude
Aug 7, 2002 02:40 PM
