how do you remove silicon spray form window?
My windows were squeakign when I rolled them down so we put some silicon on the corner of the doors and the squeak is gone, but theres silicon on the window now.. does anyone know how to remove the silicon?
Normal glass cleaner should do the trick
If not, try glass cleaner and instead of using a towel use black and white newspaper. The ink from the newspaper acts as a microfine polish and should remove all of the silicone.
This stuff sucks! I once sprayed onto the pwr ant. and got all over the car and rear hatch. U need chemical like Dupont No.7
Bug and Tar Remover from your local auto part store. It smells like mild kerosene. Anyway, it work but wash window or car after.
I'd say use gasolene.
Tweakie-who uses gasolene for everything, including as a replacement for a fine evening wine.
