how to remove my decals
I've always thought my hatch was rather clean, but now I want it clean-clean...sooo...
before i attempt....scrubbing, sweating, scratching up my window....
what's the easiest way to remove a decal from a window?
Thank you in advance!!!!!
Re: how to remove my decals (KillerWabbit)
I used a credit card to get the super strong military stickers (they are STRONG) off, and also to get some emblems off when I had my MR2. Then you get some goo-gone to get rid of the sticky stuff.
Re: how to remove my decals (piaadoll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piaadoll »</TD></TR><TR><TD CLASS="quote">what's the easiest way to remove a decal from a window?</TD></TR></TABLE>
get a flat razor blade, spray windex on sticker and slowly work the blade under the decal. be sure it's wet otherwise the adhesive will smear all over the glass and is a pita to get off. when you're finished, you can clean it up with some goo gone
Re: how to remove my decals (cre18)
WD-40 is the shizzzz.
also try nail polish remover to remove the stuff left behind after using a razorblade - stinks like hell but works great.
but dont get that stuff on the paint - because it might dull the finish
Re: how to remove my decals (NatedoggAZ)
windex and a razor blade, but put the windex on first and coat the hell out of it. use the razor blade and it willl come off easy as hell.
Re: (Philip)
what is the best way to get the "civic ex" stickers off the trunk?... i wont take a razor to it... dont wanna scratch the paint... but willl the wb40 be ok on the paint?... or should i just go with the hairdryer and goo gone?... thanks...
can I haz?
Re: (1.8T_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8T_EG »</TD></TR><TR><TD CLASS="quote">what is the best way to get the "civic ex" stickers off the trunk?... i wont take a razor to it... dont wanna scratch the paint... but willl the wb40 be ok on the paint?... or should i just go with the hairdryer and goo gone?... thanks...</TD></TR></TABLE>
buff it out
buff it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerWabbit »</TD></TR><TR><TD CLASS="quote">youre going to have to replace your window. </TD></TR></TABLE>
lol....
lol....
Re: (1.8T_EG)
i took fishing line and wedged it behind the emblem and worked it off, then used simple green to get the adhesive off with my fingernail. Than I waxed. This was for a car dealership emblem though.
Re: (Philip)
NOOOOOO RAZOR BLADE! It WILL scratch your car no matter how careful
this is what I did to remove my pinstripe and other crap
1. Hair dryer or heat gun. Heat up a small section.
2. You should be able to peel it off with your fingernails, pick at a corner until it comes up
3. Heat and then peel the rest of the decal off
4. Automotive goo gone should take th gunk off
But it should be ALOT easier since the decal is on your windows and not the car body itself
Re: (silvercivicgrl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvercivicgrl »</TD></TR><TR><TD CLASS="quote">NOOOOOO RAZOR BLADE! It WILL scratch your car no matter how careful</TD></TR></TABLE>
if you scratch your window with a razor blade while trying to remove a sticker, you are a **** ****.
i have taken off plenty of stickers, on contoured windows, convexed, you name it, and have never scratched anything.
