should i go hybrid turbo?
Old Sep 8, 2002 | 03:08 PM
B18C-Hatch's Avatar
New User
Default should i go hybrid turbo?
i have a stock B18C in my hatch and found a T3/04e Turbo kit for $3400. I was planning on going NA (becasue i got B18C) but i can be in the 11's with this setup. If i don't go turbo i will go with JUN 3 cams. I will be doing the install by myself so there is no cost to install.
any opinions? thanks.
Old Sep 8, 2002 | 03:45 PM
Foozball26's Avatar
Default Re: should i go hybrid turbo? (B18C-Hatch)
Well it totoally depends on what you want, but if you want opinions I would go turbo. The power you get from a turbo is alot easier and cheaper than you could ever get from a NA setup.
although, in order for you to get into the 11's you'll need a built bottem end so you can run more than about 9 psi.
plus the sweetest sound in the world is the snail spooling up and if you couple that with a kickass bov then you are in heavan.
gl with your desicion
PowerlineDom
Nov 27, 2012 12:10 PM
dpine
Dec 17, 2011 04:06 PM
SunDropCRX
Oct 7, 2008 08:14 AM
skcivic4life
Oct 26, 2007 12:07 PM
**DOHC HaTcH**
Feb 8, 2006 10:27 AM
