99 civic si cranks and wants to start but wonkick over please help
Old Mar 14, 2010 | 06:56 AM
blksi99's Avatar
Default 99 civic si cranks and wants to start but wonkick over please help
i alread replace coil cap rotor plugs wires it sounds like it wants to start but just wont kick over i need help real bad this is my dailey driver
Old Mar 14, 2010 | 10:39 AM
RCurioso88's Avatar
Default Re: 99 civic si cranks and wants to start but wonkick over please help
did you check the main relay?
Old Mar 14, 2010 | 06:27 PM
blksi99's Avatar
where is the main relay please help this is my everyday car
Old Mar 14, 2010 | 06:33 PM
raphael's Avatar
Main Relay is under the passenger side dash. Remove glove compartment and look to you right and there it is . Under the pass. vent. You'd know its no good because you won't hear a loud click from the pass. side when you turn the key to ON.
Old Mar 14, 2010 | 06:44 PM
angel_i's Avatar
Pull the valve cover off and check to see if the timing belt is broke.
Old Mar 14, 2010 | 07:04 PM
blksi99's Avatar
timing belt isnt broke i said it trys to start
Old Mar 14, 2010 | 07:22 PM
blksi99's Avatar
i checked the main relay it clicks when i turn the key on so i guess it works
Old Mar 22, 2010 | 06:55 AM
b16_swap's Avatar
Check to see if your getting fuel
Old Mar 22, 2010 | 08:21 AM
nsxter's Avatar
the firing order is probably wrong its a noob mistake
Old Mar 22, 2010 | 08:49 AM
dpetro1's Avatar
agreed. if it just started happening after you changed the wires then you need to double check firing order
Old Mar 22, 2010 | 09:03 AM
rycrkt's Avatar
Ground wires?
Old May 31, 2010 | 12:32 AM
hondatek614's Avatar
ever get this problem worked out? curious to hear what the issue was.
i have been intermittently called on to help a friend with his 2000 SI which has been having a similar problem. i had to replace the main relay in my 1989 CRX SI back in the day, and overall it sounds like a pretty similar issue. car turns over, but just doesn't "start". spark is there. fuel is questionable. car every once in a while will start normally. moisture doesn't seem to be an issue. heat +/- may be an issue (seems to happen more often).
personally if this problem is surfacing i think honda has some answering to do with its (often loyal) customers. this was a widespread issue on older civics/crx's, and it would be a shame if the same problem is emerging with the next generation.
CHONCH2
14
Jan 21, 2010 10:26 AM
RyanAutry
Dec 14, 2009 02:22 PM
06turbocivic18
Oct 13, 2009 10:04 AM
91rexhf
10
Dec 27, 2008 05:06 PM
AzBlackTeg
Oct 10, 2004 05:36 PM
