99 civic si cranks and wants to start but wonkick over please help
i alread replace coil cap rotor plugs wires it sounds like it wants to start but just wont kick over i need help real bad this is my dailey driver
Re: 99 civic si cranks and wants to start but wonkick over please help
Main Relay is under the passenger side dash. Remove glove compartment and look to you right and there it is . Under the pass. vent. You'd know its no good because you won't hear a loud click from the pass. side when you turn the key to ON.
ever get this problem worked out? curious to hear what the issue was.
i have been intermittently called on to help a friend with his 2000 SI which has been having a similar problem. i had to replace the main relay in my 1989 CRX SI back in the day, and overall it sounds like a pretty similar issue. car turns over, but just doesn't "start". spark is there. fuel is questionable. car every once in a while will start normally. moisture doesn't seem to be an issue. heat +/- may be an issue (seems to happen more often).
personally if this problem is surfacing i think honda has some answering to do with its (often loyal) customers. this was a widespread issue on older civics/crx's, and it would be a shame if the same problem is emerging with the next generation.
CHONCH2
14
01-21-2010 10:26 AM
06turbocivic18
10-13-2009 10:04 AM
