81mm HG on 81.5mm bore?
Guys
the title is pretty much self explanatory, however I'll give a bit more info. I got a built b18c6(edm). The cometic headgasket gave up on it andthe car started to use coolant. Leakdown confirmed cylinder three was where it was leaking. The bore on the car is 81.5mm with wiseco pistons. I requested a cometic 81.5mm gasket but the retailer sent a 81mm by mistake. My question:-
can I use the 81mm cometic gasket on my 81.5mm block?
Also have you guys had any problems with cometics?
yes you can run the stock gasket on 81.5mm bore. When honda rebuilds an engine nd uses overbore they use stock gaskets. ive been running stock gaskets in every motor with no problem and hundreds of other if nto thousands
Thanks for the reply, the head is going on tommorow so I need to be 100 per cent certain it'll work. So a 81mm cometic on a 81.5mm block.
I'd be content with your answer if I had a stock oem gasket, the one I have is a comtic 81 mm. Any different to oem?
[QUOTE=CarbonTarponSol;52218808]
No they sell 84mm gaskets bro come on Golden Eagle makes one!
[QUOTE=khrys771;52218839]
getgot22
Mar 27, 2006 06:28 PM
W O T
Mar 23, 2006 12:57 AM
