car won't run with MAP plugged in
Old Mar 11, 2010 | 03:21 PM
brutekiller787's Avatar
Default car won't run with MAP plugged in
so i just installed my turbo kit and now my car will idle fine with the MAP plugged in, but as soon as i give it any amount of throttle, it immediately dies. i tried swapping the TPS and MAP plugs, didn't work. it runs with the map disconnected, but the idle is very crappy. it worked fine with my old ecu so what could it be? thanks for your help
Old Mar 12, 2010 | 08:57 AM
Default Re: car won't run with MAP plugged in
up
Old Mar 12, 2010 | 09:49 AM
CivicSD's Avatar
bad map sensor
Old Mar 12, 2010 | 06:12 PM
no cuz it worked with my stock ecu. then i converted to obd1 with a stock d15b2 map set up for the dsm 450's i have installed and now it won't work. if i plug the stock ecu back in it works fine.
carlos8
36
May 4, 2014 05:42 AM
boostedcivicsir
Jul 24, 2007 11:49 AM
boostedcivicsir
Jul 24, 2007 06:17 AM
BluntMan
Mar 4, 2004 07:05 AM
