EG Civic just dies... really strange.
Old Mar 11, 2010 | 07:29 AM
johnny hatchback's Avatar
Default EG Civic just dies... really strange.
So i have been helping my cousin with his EG. Just to give you history, the car is an EX, was swapped with a B18C1, got stolen, he bought a Z6 to put back in it and that's where it's at right now.
So the car runs great, idles fine, no problems, no CEL, nada...
then as it's idling it just shuts off like it's on a timer. I can't figure out what is happening but the car just shuts off and then it turns over and sometimes even starts right back up. Then runs for awhile and shuts off again.
thoughts?
Default Re: EG Civic just dies... really strange.
PS, we replaced the main fuel relay already...it's not that.
Old Mar 11, 2010 | 10:43 AM
johnzy00's Avatar
Not saying anything bad but what about gas? bad? low? water? Did you check fuel pressures?
Old Mar 11, 2010 | 10:51 AM
All fluids were replaced and refilled. If it was bad or old gas I would think it would run rough but while its running it runs great. You can drive it around but after a certain amount of time it shuts off.
Old Mar 11, 2010 | 10:52 AM
*96EK*baybay's Avatar
it could be a distributor that going bad try replacing it, but it could also mean that either the engine needs oil or that a piston is no good.
Old Mar 11, 2010 | 10:55 AM
johnzy00's Avatar
UHM WHAT????
You was almost on to something then did you fall in the middle of that sentence and hit your head?
Old Mar 11, 2010 | 10:57 AM
johnzy00's Avatar
What about possibly overheating? Do you have a good temp gauge?
Old Mar 11, 2010 | 11:01 AM
I thought it was temp maybe too, gauge doesn't go above half, stays where it normally should... its like the engine knows something is wrong so it just shuts off, but no codes...?
Old Mar 11, 2010 | 11:04 AM
If a piston is going bad your car tends to shut off after a while. The car will usually turn off when your idleing.
johnzy00's Avatar
Happen to look at the fan to see if it's kicking on? Overheating would def do that! Possible that you may have the wrong wiring to the ect? Do you have a temp gun to varify?
Old Mar 11, 2010 | 11:06 AM
johnzy00's Avatar
Ok I will try to follow you but let me ask how does a piston START TO GO BAD? I thought they were bad or they were good no inbetween. Rings can start to go bad pistons not sure about that. But would love to learn if i'm wrong!
Also if your run a car will little oil for a long time the pistons will fry resulting in a car that starts but will turn off after a while.
Old Mar 11, 2010 | 11:08 AM
LOL MY BAD I KEEP FORGETTING TO WRITE PISTON RINGS
Old Mar 11, 2010 | 11:09 AM
Originally Posted by johnzy00
UHM WHAT????
I meant piston rings
Old Mar 11, 2010 | 11:14 AM
johnzy00's Avatar
????? Moving on!
Johnny I would def look into temp situation!
When the car dies does it sputter on it's face before it quits like it's trying to fix it's self or just running great idling great and then it's just like you turn the key off?
chrstphr25
10
Jun 15, 2009 11:13 PM
streetfame973
Jun 10, 2009 10:19 AM
classciv
Jul 1, 2005 05:18 AM
stickyfingers
Mar 12, 2004 08:39 PM
Fuster_Cluck
11
Feb 20, 2003 11:52 AM
