EG Civic just dies... really strange.
So i have been helping my cousin with his EG. Just to give you history, the car is an EX, was swapped with a B18C1, got stolen, he bought a Z6 to put back in it and that's where it's at right now.
So the car runs great, idles fine, no problems, no CEL, nada...
then as it's idling it just shuts off like it's on a timer. I can't figure out what is happening but the car just shuts off and then it turns over and sometimes even starts right back up. Then runs for awhile and shuts off again.
thoughts?
thoughts?
Re: EG Civic just dies... really strange.
All fluids were replaced and refilled. If it was bad or old gas I would think it would run rough but while its running it runs great. You can drive it around but after a certain amount of time it shuts off.
it could be a distributor that going bad try replacing it, but it could also mean that either the engine needs oil or that a piston is no good.
I thought it was temp maybe too, gauge doesn't go above half, stays where it normally should... its like the engine knows something is wrong so it just shuts off, but no codes...?
Happen to look at the fan to see if it's kicking on? Overheating would def do that! Possible that you may have the wrong wiring to the ect? Do you have a temp gun to varify?
Ok I will try to follow you but let me ask how does a piston START TO GO BAD? I thought they were bad or they were good no inbetween. Rings can start to go bad pistons not sure about that. But would love to learn if i'm wrong!
????? Moving on!
Johnny I would def look into temp situation!
When the car dies does it sputter on it's face before it quits like it's trying to fix it's self or just running great idling great and then it's just like you turn the key off?
chrstphr25
10
06-15-2009 11:13 PM
streetfame973
06-10-2009 10:19 AM
stickyfingers
03-12-2004 08:39 PM
Fuster_Cluck
11
02-20-2003 11:52 AM
