del sol brake question
Old Mar 8, 2010 | 08:17 PM
blaze2010's Avatar
Default del sol brake question
k i have a 95 sol vtec:
front brake size?
and is there a difference between abs and non abs calipers?
i ask cuz i got a 11in fastbrakes kit lyin around and was wonderin if i could put it to use...
also are teg rear disks the same size as my sols cuz again i got parts lyin around and want them to go to work
thanks
Old Mar 9, 2010 | 03:51 AM
ChrisRogers's Avatar
Default Re: del sol brake question
https://honda-tech.com/forums/tech-misc-15/reference-brake-rotor-sizes-928196/
I dont think you could use Integra rotors unless you do a complete brake swap.
Old Mar 9, 2010 | 06:11 AM
dpetro1's Avatar
i was under the impression that del sol vtec w/ abs has 262mm rotors and non-abs is 240mm rotors. in 94 abs was optional then became standard equipment in 95.
Old Mar 9, 2010 | 06:15 PM
blaze2010's Avatar
now this may sound dumb but what wou stop me from using the 11in rotor just not the caliper? would it be width or the dia of rotor? and could i just use the caliper mount from the fastbrakes kit? or would the caliper not grip the new rotor diameter properly
Old Mar 11, 2010 | 02:00 PM
blaze2010's Avatar
? anybody got more info?
Jdcamaros
Jul 30, 2011 02:09 PM
robbys89
10
May 16, 2010 09:20 AM
gmacarize
12
Oct 27, 2008 06:26 PM
delsolnewkid
Mar 13, 2006 07:20 AM
EG2Driver
Oct 15, 2005 03:12 PM
