90 civic help p-p-p-plleasse
ok well so my girlfriends car has been having some problems lately.
i dont know what exact motoris in it.. just the 1.5? and well it had some problems with staying running and dieing every now and then. when it dies it the ecu throws code 15. we've replaced fuel pump fuel filter spark plugs wires cap rotor ignition coil and it just wont stay running. any ideas? code 15 says in the haynes book. could be igniter..isnt that the coil? or is it something seperate in the dizzy?
The ignitor is not the same thing as a coil. You'll more than likely need to replace the entire distributor if you can't find an ignitor by itself to replace yours/hers with.
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal (I.E. ignitor)
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
With a failing ignitor you will also get a jumping tach
thank YOU.!! omgahhh you saved my life i just spent all day restoring some much needed TLC on this 90 SI i just bought 2 days ago and this code threw and i couldnt figure it out, i knew it to do something with the distirbutor and you just reassured me so now im off to buy and replace mine.
the jumping tach really gave it away.
yah, my boys car was doin that same **** as well. i pulled the motor to put on a new trans(the lazy method, less strain) and i tried extending the plug onto its perch clip(or mounting point) and might have extended the wires a little to much, i removed the screw checked the connections and pushed the wires a little more into their ports. started it up n it ran!
SOHC_MShue
16
Dec 4, 2003 07:16 PM
