Opinions on D16Y7 turbo setup
Old Mar 6, 2010 | 10:43 PM
96romaEK's Avatar
Default Opinions on D16Y7 turbo setup
Below is my current parts list. Anyone else have a setup similar to this that can comment on it's reliability and/or power output? Not looking at making much power up front. Just to add a little power to the car for now. I do plan on purchasing a second SOHC block to build up for higher boost numbers over the summer. As usual I would like to keep costs down.
- T25 turbo (used from Nissan Silvia)
- turbo manifold (any suggestions? maybe cast, no external gate)
- Injectors (440-550cc. any OEM injectors?)
- eBay intercooler and piping (modified to fit, then powder coated)
- Y8 intake manifold
- 255lph Walbro fuel pump
Both the hot side of the turbo and the manifold will be ceramic coated before install. As far as engine management goes, I'm going to try and find a used Hondata. If I can't find one before install time, then an OBD1 conversion running one of the tuning programs will do fine I think.
Any suggestions or ideas will be greatly appreciated.
Old Mar 7, 2010 | 01:40 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: Opinions on D16Y7 turbo setup
run some dsm 450's in it, a HF manifold with an adapter plate and have a professional tuner tune it. also get ngk bkr7e spark plugs for it (part number 4644) and gap them to .028"
take your time and make sure you have everything you need and read read read. till you understand it.
Old Mar 7, 2010 | 09:05 AM
96romaEK's Avatar
I've had turbo cars before, so I know what to expect with tuning, etc. I'll have to travel a couple hundred miles to get it tuned, but I am prepared to do that.
hybridmiklo
Sep 4, 2011 01:08 PM
jpo20
Apr 10, 2009 07:21 AM
94c1v1cex
Oct 22, 2007 08:57 PM
jdm_sir2
Aug 3, 2007 08:03 PM
IGotVTECyo
Oct 2, 2005 09:45 AM
