would overfilling my oil cause it to leak?
Old Sep 7, 2002 | 10:27 PM
keebler65's Avatar
Default would overfilling my oil cause it to leak?
after a recent oil change, my car has started leaking oil. i noticed after the change that i had overfilled it a little....about 1/4" above the top hole on the dipstick. would this be what cause the leak? thanks
Old Sep 7, 2002 | 11:17 PM
frogsr's Avatar
Default Re: would overfilling my oil cause it to leak? (keebler65)
where is it leaking? and overfilling that much is horrible for your engine. drain it and put it between the two marks on the dipstick.
Old Sep 8, 2002 | 03:39 AM
MikeSarr_GSR's Avatar
Default Re: would overfilling my oil cause it to leak? (frogsr)
what motor is it? if it is B series VTEC 4.20 is reccomended and .20 is
about 1/4 over the top line. you can run up to 5qt them safely according
to my guy who is an ASC master tech in honda/acura. I run 4.2-4.5 and
I ten to take his advice. I havent seen any issues, remember VTEC needs
a healthy oil level.
Old Sep 8, 2002 | 07:31 AM
earl's Avatar
#1 check to see if u are leaking at the oil filter (may need to be tightened more) or #2 check to see if you are leaking at the drain plug (may need a new plug gasket/washer). One extra quart will not necessarily cause an oil leak but not good for your motor either.
Old Sep 8, 2002 | 08:06 AM
Rocket's Avatar
Default Re: would overfilling my oil cause it to leak? (earl)
Good point Earl. Do not over fill your engine with oil.
If the oil level is high enough the crank will be whipping thru the oil and create bubbles in oil and bubbles don't lubricate well.
Old Sep 8, 2002 | 11:11 AM
keebler65's Avatar
Default Re: would overfilling my oil cause it to leak? (Rocket)
ok thx guys for the info. i havent been able to trace the leak yet.
Old Nov 13, 2002 | 05:14 AM
95GS-Racin's Avatar
I almost overfilled mine last time i changed my oil, and i checked it and had to drain some. Did you get a new filter and chrush ring?
Old Nov 13, 2002 | 12:06 PM
R@mon's Avatar
Default Re: would overfilling my oil cause it to leak? (95GS-Racin)
could too much oil actually hurt the motor seriuosly? like i put 5 or 6 quarts?
Old Nov 13, 2002 | 12:26 PM
Desslok's Avatar
Default Re: would overfilling my oil cause it to leak? (93h22a4)
It can blow seals, especially if you already have a weak seal/high mileage.
Old Nov 13, 2002 | 02:27 PM
sauceman's Avatar
Default Re: would overfilling my oil cause it to leak? (sp)
Why would you do that anyway? It only takes 4 or 5 pints
Old Nov 13, 2002 | 02:33 PM
R@mon's Avatar
Default Re: would overfilling my oil cause it to leak? (sauceman77)
i know but i once read in sport compact car that they mistakenly put8 quarts of oil in the project civic(eg) because thy thought the old oil had already been drained. sucks to be them
DO_ITR_YoungD_19
Honda S2000
11
Nov 24, 2008 08:38 PM
GSR_hatch936
33
May 8, 2007 08:41 PM
92redhatch
Aug 27, 2006 09:52 AM
Campee
Sep 5, 2003 11:19 AM
95gsr
Mar 12, 2002 01:49 PM
