CEL code 23, knock sensor. How do I fix???
Old Sep 7, 2002 | 08:44 PM
Thagreybomber's Avatar
Default CEL code 23, knock sensor. How do I fix???
I've gotten a CEL for knock sensor. How do I fix it? I've checked the plug to see if it's in all the way, good. I've checked the connection on the ecu, good. The wire from the plug to the ecu is good. What else should I look at to remedy this problem?
Sometimes it'll come on, sometimes it doesn't. That has happened only a few times though. It usually comes on while normal driving, at about 3500-4000rpm on the freeway.
HELP! TIA
Old Sep 8, 2002 | 06:44 AM
Mikey3000's Avatar
Default Re: CEL code 23, knock sensor. How do I fix??? (Thagreybomber)
check if the knock sensor is broken. have u done that yet?
Old Sep 8, 2002 | 10:47 PM
Default Re: CEL code 23, knock sensor. How do I fix??? (Salvatore Leone)
how do I check that and what am I checking for...i.e. will it appear/feel broken? Where the sensor is located, that is a pretty tight area.
Old Sep 9, 2002 | 07:17 AM
Mikey3000's Avatar
yeah 1st check if it's physically broken. if it isn't, i believe there's a test for it in the helms. i'm not sure though.
Apex1972
Feb 12, 2008 09:55 AM
oranginal
Jul 6, 2006 02:17 PM
petarr
Mar 4, 2006 10:37 AM
hybrider
Feb 21, 2003 09:50 PM
Thagreybomber
Sep 11, 2002 10:16 PM
