My ECU Fuse keeps on blowing PLEASE HELP
I was driving, the suddenly my car died, i checked for spark, fuels, thers was nothing, i check the fuse box, the ECU fuse were blow, then i replaced it, then it blow again when i turn on the keys, Can any one thinks of what could have been the problems or how to check it?? I replace the ECU with the same one but the fuse still blowing, PLEASE HELP
will some where along in the swap you have done somthing BAD !! you got your self a short out some where !!... now good luck lookin !! ... all ways check and check agian when doin somthing like that !!....
Guest
Posts: n/a
Please, MORE HELP
Think back, what did you do to the car that might have caused the ECU fuse to blow?
Install a new part?
Work on something?
There is something you did that caused this, you just need to figure it out.
yea you need to inspect every inch of the wiring harness
have fun.
have fun.
have fun.
have fun.
buy or borrow a multimeter. check for contiunity between all the wires (except wires that should be grounded) and a known ground
Guest
Posts: n/a
Install a new part?
Work on something?
Install a new part?
Work on something?
i just change my Intake Manifold to the ITR, not it's nothing related to the Wiring, Do u know which wire that could cause a shock on it?
There you have it. Something is grounding out somewhere near the intake manifold. Find it and fix it.
But where could it be on the intake Manifold?
Guest
Posts: n/a
Kid-jdm-teggy
17
Jan 28, 2015 08:57 PM
