99 civic Overheating Problem!!! NO Clue WHY
Old Mar 4, 2010 | 04:00 PM
ERIC1's Avatar
Default 99 civic Overheating Problem!!! NO Clue WHY
I bought the car had no problem then after a few months it started overheating bought some coolent cuz it was low...Then a few weeks later it overheated again so this time i just put water in it an thought it had a leak looked for the leak and nothing! i add more water to it and in a couple of days its gone and overheats! i changed out the thermostat and still have the problem
and the car dosent smoke so i dont think its burning the water.
So Help What to do????
Old Mar 4, 2010 | 04:05 PM
EJ1 JDM Boostin's Avatar
Default Re: 99 civic Overheating Problem!!! NO Clue WHY
does ur oil look like a milk shake
ur heater core could be leaking
Old Mar 4, 2010 | 04:06 PM
Former User's Avatar
When you remove the radiator cap (when engine has cooled), do you see bubbles or oil in the coolant?
Old Mar 4, 2010 | 04:32 PM
ERIC1's Avatar
The oil looks normal.. and radiator goes dry so i cant tell but i dont think so
Old Mar 4, 2010 | 04:34 PM
Pressure test the cooling system.
Old Mar 4, 2010 | 04:44 PM
ERIC1's Avatar
ok but HOW?
Old Mar 4, 2010 | 04:54 PM
David12's Avatar
with this
http://www.amazon.com/dp/B0002SRGWU?tag=ppl-20
Old Mar 4, 2010 | 04:56 PM
It's also possible that some auto parts stores will rent the device. Call around to find out.
Old Mar 4, 2010 | 04:58 PM
D Griff's Avatar
Autozone will loan a lot of things for "free". You pay for it, then when you bring it back they give you the Cash back.
Old Mar 5, 2010 | 05:05 PM
ERIC1's Avatar
Noticed the fan is not turning on could that cause the problem even tho we have cold weather
Old Mar 9, 2010 | 04:42 AM
n/ahonda97's Avatar
yeah, i am in the same boat already replaced a head gasket,put new head bolts on and still have this problem.got a good friend and cert mach looking at it now....no smoke no oil in coolant or coolant in the oil...she just runs above norm alot...coolant keeps evaporating bc of heat..fan works and new (190) thermo. who knows we will see..
Old Mar 9, 2010 | 06:01 AM
BoostdKseries's Avatar
Yeah if you're fans aren't turning on then that could possibly be you're problem. I had an accord with the same symptoms and finally realized the fans weren't kicking on and then I fixed that and it was fine. Also when the heater core went out it would overheat. But i also wouldn't have heater either. Good luck
Old Mar 9, 2010 | 06:14 AM
dpetro1's Avatar
the fan is not going to turn on if there is no/low coolant in the system. you have a leak, you need to have the system pressure tested. coolant cant just disappear.
redrix
Jun 5, 2014 12:38 PM
roadromper1
Honda Civic (2001 - 2005)
28
Aug 20, 2010 02:41 PM
noob101
Apr 27, 2006 05:09 AM
tdo
Feb 19, 2005 05:49 PM
SPORT INJECTION
Aug 25, 2003 12:15 PM
