Help!! i got a radiator problem !!
Old Feb 10, 2005 | 10:33 PM
tdo's Avatar
tdo
Default Help!! i got a radiator problem !!
I did a couple searches and didnt find anything on my problem.
Just recently i was driving and noticed my car got a little hot, so i pulled over and look under the hood. I looked in the coolant bottle and there was nothing in there so i put some water in there and it was fine. Then i went home and put some coolant in there.
Then the next day i come home from school and when i got home i checked to see if i needed more coolant but there was nothing in there. WTF ?!?!
ok ... now i put some coolant in and i look under my car for a while.... nothign comes out. So i start up my car and look under and still nothing comes out. So now im thinking it might be a blown head gasket? or it might be getting into the motor?
I check my oil stick and it looks fine. o yea i changed my oil a couple days earlyer and the oil looks fine. How do you know if theres water in the oil? when i checked my oil it looks a light brown. and when i start up my car, it starts up with no trouble and when i drive its just fine. I hit vtec and its normal too.
anyone have any idea where my coolant went? help me plz.
its been like 4 days now.
Old Feb 10, 2005 | 10:38 PM
ekb16's Avatar
might be leaking under the motor or some place else.
Old Feb 10, 2005 | 10:40 PM
tdo's Avatar
tdo
Default Re: (ekb16)
the thing is i dont see no coolant on the ground when i move my car. no kind of white smoke when i drive either. If it was under the engine would it make a puddle of water/coolant?
Old Feb 10, 2005 | 11:06 PM
ekb16's Avatar
if wouldnt make a puddle unless its leakin really bad...park your car in the driveway overnight and in the morning move your car and see if there is anything on the ground that wasnt there yesterday..if there is then the chances are its leakin from the under the engine somewhere.
Old Feb 10, 2005 | 11:07 PM
tdo's Avatar
tdo
Default Re: (ekb16)
i let my car on jack stands and came back 15mins later and found 5 small a$$ spots of water. I go under and look and my tranny is kinda wet..... is the water pump near the tranny? wheres the water pump located at?
Old Feb 10, 2005 | 11:17 PM
tdo's Avatar
tdo
Default Re: (tdo)
ok since the tranny was a lil wet i checked the top and find it a little wet there too. and i lift up the spark plug wires and see a small hoses about 1in diameter .... is that a radiator hoses?
Old Feb 11, 2005 | 12:53 AM
chiggy's Avatar
Default Re: Help!! i got a radiator problem !! (tdo)
what kind of car do you have? I've got a coolant leak on my car that is about to be fixed. the reason for mine is I mistakenly overtightend the bolts for the intake manifold and it cracked the hondata gasket I have for my Skunk2 intake manifold on my GSR. I thought it was the headgasket at first too. sometimes you can also have a pinhole in one of your hoses that doesn't leak untill you are driving and the water pump is putting more pressure to it than at idle.
now for a question I have. will a fluidyne radiator from a CRX with FAL fans on it fit on my 99 GSR?
Old Feb 11, 2005 | 01:27 AM
tdo's Avatar
tdo
Default Re: Help!! i got a radiator problem !! (chiggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chiggy &raquo;</TD></TR><TR><TD CLASS="quote">what kind of car do you have?
now for a question I have. will a fluidyne radiator from a CRX with FAL fans on it fit on my 99 GSR? </TD></TR></TABLE>
a honda prelude
and about your question, im pretty sure it would wit. wouldnt it be kinda small though?
Old Feb 11, 2005 | 07:16 AM
PrettyLude's Avatar
when was the last time you changed your radiator cap? try changing that to see if it helps
Old Feb 11, 2005 | 06:00 PM
tdo's Avatar
tdo
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">when was the last time you changed your radiator cap? try changing that to see if it helps</TD></TR></TABLE>
doesnt look like its coming from the cap.
Old Feb 11, 2005 | 07:11 PM
tdo's Avatar
tdo
Default Re: (tdo)
Heres some pics.
This is the hoses im talking about.
This is where it goes.... it connects to this thing and comes out the other side
After taht it goes into the firewall. Its the hoses on the right
Is that a hoses for the radiator? because i think thats the hoses that is leaking.
Old Feb 11, 2005 | 07:18 PM
mmuller's Avatar
Mad Scientist
Default Re: (tdo)
yeah all those carry coolant.
fill it up with water; turn the car on, let the system pressurize and look for leaks.
Old Feb 11, 2005 | 09:00 PM
vtekstorm's Avatar
Default Re: (mmuller)
yea that hose carries coolant das for your heatin system.just replace that water hose n u should be good
Old Feb 19, 2005 | 05:49 PM
tdo's Avatar
tdo
Default Re: (vtekstorm)
thnx for help guys
profesional-hobo
Apr 17, 2009 07:28 AM
hAtChBaCkFoReVeR
Nov 12, 2008 12:01 PM
tdo
Feb 14, 2005 04:07 AM
92jdmhatch
10
Dec 28, 2004 07:53 PM
SPORT INJECTION
Aug 25, 2003 12:15 PM
