need help fuse15 keeps blowing out
Old Mar 3, 2010 | 06:42 PM
DjDex1Ek's Avatar
New User
Default need help fuse15 keeps blowing out
Alright my fuse 15 keep blowing out speedometer going crazy and lights are dimming, I looked under the car did the whole take off the intake manifold bracket i checked all the wires on the harness but none of them were bare all looked good also checked the alternator voltage is good any other ideas what it might be???
Old Mar 3, 2010 | 07:06 PM
Former User's Avatar
Default Re: need help fuse15 keeps blowing out
Have you read this TSB?
Old Mar 3, 2010 | 07:29 PM
DjDex1Ek's Avatar
New User
yeah I checked all the wires on the harness open the loom but none of the wires were showing all looked good i separated them all
Old Mar 3, 2010 | 10:12 PM
ke98248's Avatar
either you have a bad alternator, bad speed sensor, or most likely: a wire or wires grounding out thru the car. I had this same problem, when i replaced my clutch, i forgot to make sure my 02 sensor (primary) wiring was tucked out of the way of my down-pipe. well 4 weeks later it rubbed thru the insulation and blew my speed sensor fuse. Check the engine bay for any wires like that that could have worn thru.
slo97civic
Mar 6, 2007 08:30 PM
SkIp_Civic_Ek6
Oct 31, 2006 08:53 PM
~MIF~
Aug 31, 2006 04:51 AM
CA6VTEC
Aug 2, 2006 05:31 PM
Civicse
Feb 7, 2006 04:12 PM
