Taking off the Rod end Cap?
Old Sep 7, 2002 | 06:13 PM
Ri5e's Avatar
Default Taking off the Rod end Cap?
I'm trying to pull out some eagle rod end caps off. Already unbolted the 2 bolts holding it...but can't get the end cap to pop off. I tried using a vise grip and pulling but it wont budge. Any tricks?
Old Sep 7, 2002 | 06:18 PM
earl's Avatar
Default Re: Taking off the Rod end Cap? (CRV Monster)
Hope you didn't scar the rod. Screw the bolts part way in and tap the head of the bolt with a plastic or wooden hammer. That should seperate top from bottom.
Old Sep 7, 2002 | 06:44 PM
Flamenco-T's Avatar
Default Re: Taking off the Rod end Cap? (earl)
if you tap one end of the rod cap with a small hammer, it'll move that side up and lower the other side. do a lil bit of tapping from one side to side, and eventually both will lifted slowly
forsakenriceboy86
Dec 7, 2009 12:05 PM
GSRCRXsi
Apr 1, 2006 10:24 PM
GSRCRXsi
Mar 31, 2006 06:15 PM
McFly
Jan 21, 2003 10:04 AM
