90 CRX Starting problems
Old Sep 7, 2002 | 03:47 PM
gcajnr21's Avatar
Default 90 CRX Starting problems
sometimes my car will crank but will not start. It seems to not be getting fuel. If I let it set a few min. It will then start fine. It has never died, Just fails to start once or twice a week. Any one have an idea?
Old Sep 7, 2002 | 06:10 PM
4wsB21a's Avatar
New User
Default Re: 90 CRX Starting problems (gcajnr21)
change the main fuel relay. it is going bad. comon thing for hondas. my crx and my prelude have both had that problem. changed the relay and no more problems.
Old Sep 8, 2002 | 09:44 AM
gcajnr21's Avatar
Default Re: 90 CRX Starting problems (4wsB21a)
Thanks for the response
My only thought was a bad connection on the Key switch.
I will get the new fuel relay and see how it does
Thanks again.
[Modified by gcajnr21, 6:44 PM 9/8/2002]
Old Sep 8, 2002 | 11:21 AM
keebler65's Avatar
or if you have soldering skills you can pop open the relay and re-solder all of the connections to the circuit board. but if you can't solder, dont try. maybe you know someone that can if you can't. anyways its an easy way to save $50
goodluck
Wazup
Dec 1, 2008 02:01 PM
kacivic
Sep 23, 2008 11:44 AM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
1slowSIrex
Jul 24, 2006 10:07 PM
hroosevelt
Jan 8, 2006 01:42 PM
