helpp. broke off head on LCA bolt
Old Mar 1, 2010 | 04:30 PM
bui1528's Avatar
Default helpp. broke off head on LCA bolt
like the title says i broke off the head on the LCA bolt.
tried to put on my new suspension and just snapped it right off.
should i try and fix this or just get a new LCA all together?
Old Mar 1, 2010 | 04:55 PM
nus_dogg's Avatar
Default Re: helpp. broke off head on LCA bolt
You'll need a new bushing. Cut out the rubber including the broken bolt inside, and break the tension of the outer ring of the old busing loose and install a new bushing.
This is very common on the 90-97 Accords.
Old Mar 1, 2010 | 07:34 PM
bui1528's Avatar
could i do that without taking the whole thing off?
im planning on getting new bushings anywho.
and the end of the bolt is still in the screw on the other side. how would i deal with that?
Old Mar 1, 2010 | 07:38 PM
slomofo's Avatar
GDD Member
Happens all the time.
You can....
- Drill the bolt out (takes FOREVER)
- Get a new strut and cut the old one off with a die grinder and press out the bushing.
- Use a die grinder to cut the welded nut off of your strut, then replace it with your own nut/bolt.
I prefer getting a new strut. If it's been on the car long eough for the lower bolt to rust itself on, then it's probably way overdue for replacement anyway.
Old Mar 1, 2010 | 07:40 PM
bui1528's Avatar
im already going to replace the strut with some koni yellows.
r there any diys out there for this?
ima lil iffy still haha.
Old Mar 1, 2010 | 07:43 PM
slomofo's Avatar
GDD Member
I doubt there's a thread pertaining to it because nobody wants to take pictures of themself die grinding their strut off.
Old Mar 1, 2010 | 07:44 PM
bui1528's Avatar
lol. good point.
so ur just saying cut off the old strut?
im guessing just the bottom part and then popping everything off?
i was originally just gnna heat up the bolt and then taking the nut off at the end and just popping it out.
Old Mar 1, 2010 | 07:49 PM
slomofo's Avatar
GDD Member
Yes, the bottom of the strut is shaped like a fork, cut the end of the fork that has the nut on it, and call it good.
Old Mar 2, 2010 | 04:25 AM
nus_dogg's Avatar
slomofo's got it.
Old Mar 2, 2010 | 04:48 AM
bui1528's Avatar
thank you guys for your help.
ill let you know how it goes.
Old Mar 4, 2010 | 05:00 PM
bui1528's Avatar
well got the strut off.
now i gotta get the bushing off.
what tool do i need? my friend tells me to use a bearing press but i dont want to mess with taking off the whole knuckle. any other ideas?
Old Mar 4, 2010 | 09:04 PM
slomofo's Avatar
GDD Member
The entire control arm is only three 17mm bolts, it's really easy to take off, but if you really want to do it on the car, you can use a GM Pitman arm puller.
This is the Honda specific bushing puller:
This is the GM Pitman arm puller:
They pretty much work the same, but with different prices. The GM Pitman arm puller can be had for as little as $5.00. Just get a socket the same size as your bushing and place it in between the puller and the old bushing to press your old bushing out.
Usually when you pull the bushing, only the rubber center section will come out, but you also have to remove metal sleeve inside, so don't forget.
Old Mar 5, 2010 | 04:07 PM
bui1528's Avatar
woopie. i got the inner part of the bushing out.
now the outter ring i need to take care of. any ideas there?
Old Mar 5, 2010 | 04:08 PM
bui1528's Avatar
nvm. i just read over ur post again. sry lol.
Old Mar 6, 2010 | 08:27 PM
bui1528's Avatar
seems like that ring is rusted in there.
ive tried getting a socket the same size as the ring.
ive tried going at it with a hacksaw.. hah.
nothing seems to work.
Old Mar 6, 2010 | 08:44 PM
HonBeer's Avatar
Doesnt anyone use an Acetylene cutting torch anymore?
Old Mar 8, 2010 | 04:57 PM
bui1528's Avatar
dang im getting nowhere it seems.
took a hacksaw to it.
now starting to pound it out with a hammer and flathead.
Old Mar 10, 2010 | 08:33 PM
bui1528's Avatar
finally got it out.
an old spindle nut, 1"x5 1/2" pipe and a 3 lb hammer did the trick.
92f22a6
Mar 6, 2014 11:01 AM
91 b20 integra
11
May 18, 2013 03:33 PM
Si_chRis
14
May 27, 2007 09:05 AM
is3oo
Oct 4, 2003 01:48 PM
92Si
Jul 25, 2001 10:37 AM
