rear disc toe problem
Old Feb 27, 2010 | 03:30 PM
brownsEF's Avatar
Default rear disc toe problem
ihad rear disc on my ef swapped them over to the rex now both of the back tires look toe d in >< was i supposed to switch somethin? or its the same
Old Feb 27, 2010 | 03:36 PM
BiGZ's Avatar
Default Re: rear disc toe problem
supposed to keep the orig front compensator arms IIRC,or that'll occur...
Old Feb 27, 2010 | 03:39 PM
brownsEF's Avatar
cool thnx man
Old Feb 27, 2010 | 04:02 PM
OddityDX's Avatar
just get it aligned and all will be fine
Old Feb 27, 2010 | 04:06 PM
brownsEF's Avatar
can u even adjust rear toe?
Old Feb 27, 2010 | 04:14 PM
lvmevo's Avatar
definately they ad just the litle compensator arm closest to the front on the rear trailing arm
Old Feb 27, 2010 | 04:16 PM
EFRue57's Avatar
stole this pic from another thread. someone else was replacing the rear trailing arm bushing and was loosening this bolt that is marked. however it is better to leave this bolt alone and to disconnect the one that holds the compensator arm to the rear trailing arm. It is a little more difficult to get to and to put back in, but you don't mess up your alignment.
the reason it adjusts your toe is because it is not a round hole that the bolt goes into with no movement. it is an oval hole that allows movement back and forth, which will cause your rear wheels to either tow in , be aligned, or tow out.
Old Feb 27, 2010 | 06:11 PM
brownsEF's Avatar
cool the pick helps out alot
Old Feb 27, 2010 | 07:01 PM
beansandrice's Avatar
No problem!
e.p
Sep 13, 2016 10:41 AM
adamkob32
Suspension & Brakes
Aug 3, 2006 06:40 PM
alwaysoverkill
Suspension & Brakes
Jan 13, 2006 07:43 AM
soundbomber
20
Jan 20, 2004 02:29 PM
