A note to people doing rear disc conversions
This is just an interesting tidbit that i found while we worked on my rear disc conversion on my 98 hatch. The Rear trailing arms are NOT needed! I realized this first hand because the rear trailing arms that were installed first were bent meaning that on one side I had +1.7 camber and +2.34 on the other side with a +14/32" toe to boot! So, to alleviate this problem, we matched up a set of trailing arms from a drum brake setup and after that, i was back on the negative camber side of things. That is all, thanks for reading. Hope this helps people out with their rear disc endeavors.
Cliff Notes: When buying rear disc conversions, MAKE SURE THE REAR TRAILING ARMS AREN'T BENT!!
If you have problems with your rear trailing arms, you can use any drum brake trailing arm and mate the rear disc, hub, and caliper to it. To do this, you'll need some crazy socket like an 18mm and some "star" head drivers.
Re: A note to people doing rear disc conversions (soundbomber)
nice info I have done two swaps myself and never ran into this. Thanks for looking out for fellow ht memebrs
Re: A note to people doing rear disc conversions (B18C2_sedan)
Thanks for the info im still gathering info on this project for this up and coming spring/summer.
Re: (8200RPM)
hmmm and I think my rear trailing arm is bent from my accident....thanks for the info I just thought about this...**** I'll go to my moms and get my drum set up back..haha
Very true, and the "socket" you need is a Torx key...
This is how I have done a couple, sometimes it's easier one way, sometimes it's easier to swap the whole arm, but if you do then you have to realign. Only thing that really sucks is when you strip the Torx nuts, and have to either drill or torch them out.
Re: A note to people doing rear disc conversions (SpeedBoi101)
Yeah the 3 bolts to get the hub off are a biotch! That's why most people swap the whole trailing arm.
Re: A note to people doing rear disc conversions (wilsel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel »</TD></TR><TR><TD CLASS="quote">Yeah the 3 bolts to get the hub off are a biotch! That's why most people swap the whole trailing arm. </TD></TR></TABLE>
There are four, and the spindle nut
repost
that faq thread at the top of the forum owns. nobody ever looks at it though..
[FAQ] Rear Disc Conversion-How To-using factory trailing arms
https://honda-tech.com/zerothread?id=426445
Re: A note to people doing rear disc conversions (92b16vx)
this my friend is a #3 star tip<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">Very true, and the "socket" you need is a Torx key...
This is how I have done a couple, sometimes it's easier one way, sometimes it's easier to swap the whole arm, but if you do then you have to realign. Only thing that really sucks is when you strip the Torx nuts, and have to either drill or torch them out.</TD></TR></TABLE>
Re: A note to people doing rear disc conversions (zseeanz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz »</TD></TR><TR><TD CLASS="quote">this my friend is a #3 star tip</TD></TR></TABLE>
Maybe you should have included the # sign in your post then, because the way you said sounded like it had three bolts holding it on
sorry man but I know what it's called. I use them almost everyday at work, fixing jet engines. Talk about horsepower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz »</TD></TR><TR><TD CLASS="quote">sorry man but I know what it's called. I use them almost everyday at work, fixing jet engines. Talk about horsepower </TD></TR></TABLE>
Haha, it's cool, I just say "gimme the star thingy"
Haha, it's cool, I just say "gimme the star thingy" </TD></TR></TABLE>werd
Yep, if you go to the How To section on the top of this section, I did a complete write up with pics and tools and how to do it. Its on page three I think. Just do a search in the archives and it will pull up a thread from about a year ago. And just for added info, this enables you to run rear discs from 91 up tegs, si's, hatch's, del sols, etc as long as you use the right e-brake cables.
seriously good info.
one of my friends did a rear disc swap on his CRX solo1 race kaah and all he had to buy from the junkyard was $100 worth of parts since he didnt replace the trailing arms! I was pissed since that is 1/3rd of what I paid for my rear disc swap because I bought the entire trailing arm and shipping costs were a beyotch!
specialized108
21
11-07-2008 04:44 PM
88 civic ef
13
01-02-2008 04:31 AM
