Dual Stage Boost Controller Pressure Source ?
Old Feb 26, 2010 | 10:32 AM
DUKE LADUKE's Avatar
Default Dual Stage Boost Controller Pressure Source ?
I switched up turbo's to a gt30r now instead of the gt28r. Now there is no nipple on the housing for me to attach the pressure/vacum source line. I have the one line hooked up to the wastegate but where do I now hook up the other ?. Could I tap into the ic pipe and put one there ? Could I put it on a nipple on the throttle body? . I called up turbosmart.com and they couldnt really help me on where to put it .
Thanks
Duke
Old Feb 26, 2010 | 02:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Dual Stage Boost Controller Pressure Source ?
i ALWAYS drill and tap the housing. you could use a vac manifold source.
i do it that way because ever since 95 when i was messing with turbo cars, i did it that way.
Old Feb 26, 2010 | 05:46 PM
could you hook it up to a nipple that is on the throttle body ? The nipple just has a cap on it now.
Or just tap into the fpr line ?
1cammerjammer
Oct 22, 2009 10:04 PM
zexifiedlude
May 24, 2006 05:42 PM
B18del-turbo
Mar 16, 2005 08:02 AM
