Starter problems??
Old Feb 26, 2010 | 10:01 AM
TheCrimsonGhost666's Avatar
Default Starter problems??
I try to start my car and it does nothing, no trying to kick over, nothing, doesnt make a sound. I keep turning the key and eventually usually after 10 or so turns of the key and letting it sit for a minute it starts right up. I originally thought it was the starter and was told when this happens just give the starter a couple wacks with the bottom of a hammer and it will work, so I tried that and it didnt work. Any other suggestions as to what the problem could be? The engine is a freshly rebuilt ls and runs great once started, just doesnt seem to want to start for some reason.
Old Feb 26, 2010 | 10:48 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Starter problems??
have the starter checkd, and try a dif battery too
Old Feb 26, 2010 | 10:57 AM
Can I have the starter checked at like advance auto parts or a place like that? and do I have to buy something for them to check it? lol
Old Feb 26, 2010 | 11:00 AM
I'm not Rick!
yeah. its free
Old Feb 26, 2010 | 01:37 PM
n/a2boost's Avatar
if your gonna bring the starter to advance auto parts might as well have them check your battery too
Old Feb 26, 2010 | 01:38 PM
fcm's Avatar
fcm
Old Fart
You need to find where the problem is, so start at the starter motor by doing a "by-pass jump", using a jumper lead, [12ga min.] connect one end to the batt. pos.(+) and touch the other end to starter solenoid input terminal, [smaller of two leads on starter motor, it can be unplugged].
Make sure car is not in gear, as engine will crank even if ign. is not on or car is in gear.
If engine cranks when you do a by-pass jump, the problem is not the starter motor or solenoid.
Need to know MM&Y of car and if it is a standard or automatic for more troubleshooting. 94
Old Feb 27, 2010 | 03:39 PM
Took it to advance and had them test the starter and battery, turned out the starter wasnt getting any amperage . . . Now does that mean the starter is bad or theres a leak somewhere in the current flow?
Old Feb 28, 2010 | 06:53 AM
fcm's Avatar
fcm
Old Fart
How did advance determine the starter was not getting "any amperage"?
Or did they just find there was nothing wrong with the starter?
As I said, you need to find where the problem is, that can not be done by pulling starter and taking it to someone to test, [unless the problem was the starter] and that you could have found out by doing a bypass jump.
Still need the MM&Y of car and if it is auto or manual transmission. 94
nogutsnoglory77
Apr 11, 2009 05:55 PM
ThatsTheTruth
Dec 7, 2006 06:40 AM
tchen415
Sep 12, 2006 04:55 PM
Touge Tuning
May 3, 2006 11:14 AM
mingchi69
Jul 14, 2003 06:14 PM
