Idle won't go below 1,000 RPM
Old Sep 7, 2002 | 08:05 AM
GreenR's Avatar
Default Idle won't go below 1,000 RPM
Installed JG 65mm throttle body and the idle won't drop below 1k.
Old Sep 7, 2002 | 08:16 AM
Ibuprofen's Avatar
Default Re: Idle won't go below 1,000 RPM (GreenR)
too much tension on throttle cable?
Old Sep 7, 2002 | 08:32 AM
GreenR's Avatar
Default Re: Idle won't go below 1,000 RPM (01-0531)
My V-AFC says that the throttle position 0%.
Old Sep 7, 2002 | 08:34 AM
Suprdave's Avatar
Throttle Idle Screw?
Also, try leaning out your VAFC @ Idle.
Suprdave
Old Sep 7, 2002 | 08:37 AM
GreenR's Avatar
Default Re: Idle won't go below 1,000 RPM (Suprdave)
Yeah I'll try to lean it out some more I turned the screw as far as I could and that got it to like 980's. Thanks
Old Sep 7, 2002 | 08:47 AM
Tweakmeister's Avatar
you're letting more air in now...the screw needs to be clean/adjusted.
Old Sep 7, 2002 | 08:50 AM
GreenR's Avatar
Default Re: Idle won't go below 1,000 RPM (Tweakmeister)
Do you mean unscrew it all the way and teh screw it back in
itzyaboyzeem03
Sep 30, 2009 04:11 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
BDogggUT34
Jan 18, 2005 04:05 PM
vtecmike1
Jul 30, 2004 02:20 PM
Na99Si
Apr 3, 2003 02:59 PM
