What do i check w/buying used transmissions?
Old Feb 24, 2010 | 11:25 PM
EG-SIXV-TEC's Avatar
Post What do i check w/buying used transmissions?
Im looking for a 5-speed manual hydraulic EX, SI, style 92-95 etc. tranny, whats the number for it/sticker.
what are some tips do i look for when buying used transmission, i know its a gamble but any tips when checking, condition, gearing, lubrication?
Old Feb 24, 2010 | 11:34 PM
BigDaddy's Avatar
Default Re: What do i check w/buying used transmissions?
here's what I like to do when buying cars...been good to me in the past....
1) Drive and shift it SLOWLY in to gears and feel for anything...does it feel like it catches anywhere?
2) Then shift it normally....feel anything?
3) Shift it faster.... feel anything?
4) How's reverse feel going into gear? Fight you at all? Put it into first and back into reverse...smooth?
5) Important...as you drive...does the tranny make any noticeable sounds....that just dont sound normal?
If it passes these test, I'm pretty satisfied that the tranny is sound. It's an old car, so as it gets older, it is what it is, but you dont want to buy anyone else's problems....
Clutch is clutch...if it goes...it is what it is...but bad synchros in a tranny is a burn...
Good luck!!
Old Feb 24, 2010 | 11:41 PM
How about when buying used transmissions? I heard something about the lube what do i look for or other things?
Old Feb 25, 2010 | 02:01 AM
24TEN's Avatar
PHANTOM MENACE
Ask the seller to open it up so you can actually inspect the synchros and hub sleeves, not to mention the shift forks. Without doing this, you're never really going to have an idea until you try to drive with it installed. You can shift it without it actually being installed but I don't really know what you'll determine from doing that since nothing is moving/spinning inside.
Old Feb 25, 2010 | 08:53 AM
since im not a mechanic when opening the cover, how do i tell if it is damaged fully or semi okay, etc., pictures were do i find them so i can compare?
also without opening it gambling on buying the tyranny how do i inspect the Oil,
i heard some guys saying check the oil before buying a used tranny what do i look for color, how do you diagnose form there??
teggy_617
May 14, 2009 05:21 PM
drewlee
Jan 8, 2004 09:36 AM
pg_thao
Apr 12, 2003 06:14 AM
OldSchoolCrxSiR
Jun 8, 2002 12:06 PM
