another "my vtec is not workin" thread
Old Feb 24, 2010 | 08:25 PM
crxfreak1117's Avatar
Default another "my vtec is not workin" thread
car: 1993 civic hatch turbo
motor: stock jdm gsr block, built jdm b16 head
here is the problem, we just got the motor together and had it tuned with vtec working. never had a problem out of it till now.
things ive checked:
oil level is good
coolant temp sensor is good
vtec solenoid is good
continuity from vtec solenoid to ecu
continuity from vtec oil pressure switch to ecu
the ground from the oil pressure switch
vss is working
and no there is no check engine light
Old Feb 24, 2010 | 08:53 PM
Red_Army's Avatar
Default Re: another "my vtec is not workin" thread
i haven't had much experince yet with fixing vtec issues so im just gonna say take it back to the shop and see if the tune just got messed up...which sounds pretty impossible.
did you change the switchover point when you did it?
Old Feb 24, 2010 | 09:01 PM
im sure the vtec engagement was moved, the car was also taken to the tuner yesterday and they hooked it to the laptop and said it wasnt working, didnt give any reasons why it wasnt working tho....
Old Feb 25, 2010 | 05:16 PM
bump
Old Feb 25, 2010 | 06:27 PM
shogee's Avatar
well is there oil pressure at the solenoid, oil getting up to the valve train? the oil holes are tiny and could get clogged up, check the screen on the solenoid?
Old Feb 25, 2010 | 06:31 PM
HondaPartsHero's Avatar
Technical Hero
my "my VTEC doesn't work" thread
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Feb 26, 2010 | 06:47 AM
T9U4ReBgO's Avatar
vTaK fLuId FtW!
Wow thats alot of info Hero.
94wip
12
Jun 20, 2024 07:23 PM
Rob1242
Aug 14, 2009 04:47 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
Jagolas
10
Aug 8, 2004 02:33 PM
Cm91h22a
Sep 9, 2003 06:59 PM
