94 civic d16z6 driveshafts dont turn
Old Feb 24, 2010 | 10:18 AM
Cotabas's Avatar
New User
Icon3 94 civic d16z6 driveshafts dont turn
ok, please help
i have a 94 civic with the 1.6 vtec d16z6
i took the tranny out to change the crank seal and realized it was the input shaft seal that was leaking so i opened the tranny and changed the seal and the bearing, i followed the fsm and i was sure i did everything right. when i got it all back together i can feel all the gears but the wheels dont move. the speedo goes up any time i give it gas, even if its not in gear. reverse makes the whiring noise. with the clutch pedal out its grinds if i try to put it in reverse or a higher gear so i know the clutch is engaging. what could it be? i put new driveaxles on so im going to check that first the guy at the dealer ship said they might be the wrong ones, but they fit in perfect.
i would appreciate any help, ideas, or advice. this is my daily driver/only car and im doing all this in the rain ill check back frequently, and post back when the drive axles are off
thanks in advance,
Morgan
Old Feb 24, 2010 | 10:20 AM
andoxviii's Avatar
Default Re: 94 civic d16z6 driveshafts dont turn
I bet you didn't push the axles all the way in...
Old Feb 24, 2010 | 10:26 AM
Linked's Avatar
passenger side axle should be flush into the tranny and the driver's side always has a 1/8 in gap for me but they work
Old Feb 24, 2010 | 12:19 PM
Cotabas's Avatar
New User
thank you for the quick replies :D
driver side axle was the wrong length... im waiting for the new from the parts store now
didnt notice last night in the dark and rain... theres something to be said for taking your time
Old Mar 28, 2013 | 09:32 AM
KingFish76's Avatar
I'm having a similar problem.
I have a 92 dx hatchback
I swaped in a D15b SOHC vtec engine off a 95
For the trans I got a 96-00 trans P4A-B000 from a d16z6 SOHC vtech
I installed the drive axles from the stock dx trans P20-a000 that I took out of my car .
when I got it all together, I got a low crackling noise coming now and then when taking off in 1st and after shifting to 2nd. and 3rd sometimes does not engage. But 4th & 5th shift smoothly every time. While other times it all works just fine.
since I'm using 92' driveaxles on a trans that is 96-00,
I was thinking that the drive axles are not compatible.
another thing is do I need to change the shift linkages too?
Or did I just get burned for a lousy trans?
any info will help.
Old Mar 28, 2013 | 10:01 AM
94EG8's Avatar
Seagull Management
You got burned. All '92 - '00 D-series axles are interchangeable, even the automatic ones. Btw, that transmission is from a D16Y8 not a Z6.
fiktion91
11
Jan 24, 2013 06:43 AM
jdmsir4dr
Jul 11, 2010 07:53 PM
funouse1989
Transmission & Drivetrain
Feb 19, 2009 06:32 PM
Aralliius
15
Jul 4, 2007 06:12 PM
