1993 4dr Auto to Manual swap problem
Clutch pedal has no pressure. WTF.
D15B7
Cx hydro Transmission
The Brand New :
Oem Clutch disc
-Pressure plate
-Flywheel
-Throw-out bearing
-Pilot bearing
-Slave cylinder
-Clutch lines
The Used :
- 1993 Civic VX clutch master cylinder
(Pulled this off the hatch a few days after it worked properly with my old B16)
Ive bled properly at the slave cylinder, two person bleeding. Making sure to refill when low while clutch pedal is down. Have gone through about a quart of Dot 3 Brake fluid.
*All of the clutch lines are perfectly clean, brand new, and tightened properly, as well as being clearly visible.
D15B7
The Brand New :
Oem Clutch disc
-Pressure plate
-Flywheel
-Throw-out bearing
-Pilot bearing
-Slave cylinder
-Clutch lines
The Used :
may be stupid but make sure the clutch pedal assembly is properly adjusted.
unscrew the line from the slave cyl and press on the clutch to ensure slave is getting pressure
make sure pressure plate to flywheel bolts are torqued to 17 or 25ft/lbs i cant remember
are you sure you bench bleed the clutch master cylinder? even if you did two man bleed the clutch, you could still have some air pockets in the master.
Surestick
Aug 23, 2006 10:56 AM
