tune-up?
Old Sep 6, 2002 | 10:07 PM
niceguy
Guest
Posts: n/a
Default tune-up?
What exactly needs to be done? I plan to do it myself instead of the dealer.thanks
Old Sep 6, 2002 | 10:14 PM
POLLO's Avatar
Default Re: tune-up? (niceguy)
Replace :
Spark Plugs
Spark plug wires
Distributor cap and rotor
Change:
Oil
Oil filter
Transmission fluid
fuel filter*That's just me*
Adjust valve lash**
Flush your coolant and insert new one***
** See qualified personel, that can do it for cheap or free if you are not capable.
***You might need to take the car to an specialist if you wish to do a total system flush as I beleive when coolant is emptied there are still residues of the old colant around the engine and its beneficial to get it all out.
Old Sep 6, 2002 | 10:22 PM
PhuckinHondas's Avatar
Default Re: tune-up? (Alberto El Bellaco)
Replace :
Spark Plugs
Spark plug wires
Change:
Oil
Oil filter
Transmission fluid
Adjust valve lash**
sounds good but
howmany miles are on the car?
Old Sep 6, 2002 | 10:36 PM
POLLO's Avatar
Default Re: tune-up? (In The 16s)
It really all depends on how hard you run your car.
In all reality the coolant flush is supposed to be done every 50k miles along with the valve adjustment, transmission fluid, and distributor cap and rotor. That's under normal driving conditions.
When people mention tune up this is what i consider it to be.
Old Sep 7, 2002 | 09:26 AM
kamaleon's Avatar
when you mention transmission fluid, this is for automatic trans only right? manuela trans shares the oil from the engine.
VTECcnIT
Nov 23, 2005 08:30 PM
coupon
Jun 2, 2005 09:56 PM
Xxcivic99xX
Aug 5, 2004 01:44 PM
VtechMixedKorean
Dec 28, 2002 01:11 PM
migs
Dec 9, 2002 03:38 PM
