Tranny problems
Old Sep 6, 2002 | 08:39 PM
pelotudo's Avatar
Default Tranny problems
I'm startin to have some troubles w/ the Si tranny. It doesn't want to go in to first at all, unless it's barely moving. If I'm stopped, and push the pedal to the floor to put it in, it feelt like it's right on the edge of going in to gear, but when I pull the clutch out the linkage will pop out a little and grind like it's not in gear. 3rd also seems to "go away" and come back. It has done it to me like 3 times now. It's like it's not there. I can find all of the other gears when this happens, and if I shift in to another gear I can then shift in to 3rd. This happens at high rpm's going from 2nd to 3rd.
It's a Si tranny w/ ACT 6puck and a Fidanza 9lb flywheel.
What does it sound like to you guys? Do you think tightening the tranny cable a little will help, or am I about to ditch the tranny for a new one?
jB
Old Sep 6, 2002 | 08:55 PM
Loco Honkey's Avatar
Default Re: Tranny problems (PeloTudo)
Clutch adjustment. Your clutch isn't disengaging all the way. Refer to any service manual for adjustment procedures if you don't know how.
Old Sep 6, 2002 | 09:01 PM
pelotudo's Avatar
Default Re: Tranny problems (F=WT)
Thanks.
I can't believe we got 21 posts in b4 the master
jB
Old Sep 6, 2002 | 09:09 PM
Master? Don't glorify them.
Old Sep 7, 2002 | 04:00 AM
pelotudo's Avatar
master (masterlock)
Old Sep 7, 2002 | 08:27 AM
Stupid Ass's Avatar
Pelu, you seem to not have ANY luck with your car... it seems almost every day you are on here posting on how to fix this or fix that...
Old Sep 7, 2002 | 09:00 AM
Default Re: Tranny problems (SOHC NoTEC)
No ****. Pelu, your car hates you. It likes me better. It told me this in an email. I'm sorry, but that's the way it is. When you deliver it, don't forget to top off the tank. Thanks.
Old Sep 7, 2002 | 09:19 AM
pelotudo's Avatar
ROFL.
Yeah, well, that's how it goes I guess. I haven't even started to open her up yet. I've only taken her a full 1/4 @ WOT like 3 times.
My B16 hated me...I made love to her every night, and that's what I get... Now the ZC-T hates me. I guess I'm just not good enough for them. I run Synthetic, I give them Mobil 93 (NOTHING ELSE), and I make sure they get NGK's... I don't know what more I can do. AHHH, LOVE HURTS!!!
jB
BTW, it's Pelo!!
Old Sep 7, 2002 | 09:51 AM
BTW, it's Pelo!!
Sure thing, Pedro.
Old Sep 7, 2002 | 11:01 AM
pelotudo's Avatar
Ok, hey.
Which was I supposed to do, tighten the adjusting nut or loosen it? It seems to me that it's not enguaging enough, so I should have tightened so that when I press the clutch it will pull the cord up more...
Whelp, I tightened it up about 3 turns; and it didn't help at all. Should I loosen it, or was I right and now I need a new tranny
jB
Old Sep 7, 2002 | 11:05 AM
Ok, hey.
jB
Well, Paco... when you turn the nut counter clockwise, you make it so the clutch engages closer to the floor, and when you turn it cockwise, it engages further from the floor. Sounds to me like you need to turn it clickwise maybe 5 or 6 times. It should start to grab about 2.5- 3" from the floor.
Old Sep 7, 2002 | 04:19 PM
4gvtec's Avatar
haha! pelo is now known as pedro:
a.k.a.: paco
hehe!!!!!!!!
Old Sep 7, 2002 | 05:01 PM
Default Re: Tranny problems (4gvtec)
a.k.a.: paco
hehe!!!!!!!!
AKAAKA: Pablo.
Old Sep 7, 2002 | 05:08 PM
4gvtec's Avatar
its paco dammit!!!!!!!!!!!
Old Sep 7, 2002 | 07:05 PM
USDM 4G VTEC's Avatar
maybe he is ramon?? who knows..............
Old Sep 7, 2002 | 08:27 PM
pelotudo's Avatar
Default Re: Tranny problems (JDM EF9)
I adjusted it, turned it like 5 times. It seems like it enguages a little further out now...but is still skipping out of first. I haven't had a problem losing 3rd again...yet.
jB
01_em2
Transmission & Drivetrain
Sep 30, 2010 02:37 PM
s2kboii
Honda S2000
Aug 16, 2005 08:41 PM
flukeDC4
Jan 15, 2005 06:41 PM
HavokB18
14
Jul 21, 2003 02:39 AM
MrBite
Jun 13, 2002 12:48 PM
