Gsr into 99-00 si
Well, my b16 crapped out on me, so i am going to order a gsr longblock from hmotors, and put that in. I was wondering what I need to swap in the gsr long block, i've read up this thread https://honda-tech.com/forums/hybrid-engine-swaps-18/jdm-gsr-b18c-into-99-00-civic-si-em1-swap-guide-howto-bible-1644898/, and it has a lot of good information on the full swap, but i'm just doing the longblock and I want to know what i need to replace? I am swapping over necessary parts from the b16.
Thanks H-T.
Thanks H-T.
You'll need a P72 ECU. And if you're going to keep it OBD2b, you'll need a way to deal with the immobilizer. You'll need to add IAB wiring.
Other than that, it should be considerably easier than a B18C1 in a 99-00 EX, because you don't have to deal with a lot of the D-series specific things, like the cat flange being wrong, the exhaust being short, the distributor plug being wrong....
You *should* be able to reuse your AC compressor bracket... I'm not 100% sure. I do know you won't be able to use the GSR bracket. Your compressor won't fit on it. Not sure about power steering.
And, just for the hell of it, here's my swapguide. Not an Si, but it's a gsr into a 99-00 Civic. Maybe you can glean a bit more information out of it:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/swapguide-00-01-b18c1-into-99-00-civic-lots-pics-2334716/
phiberoptik
Apr 23, 2002 10:24 AM
