LOL at another Endyne PCV thread. Easy ??
I just want to make sure that im on the right track
My setup, b20v turbo-400 hp, ish
this is the system for those "special" people that dont know what the endyn system look like lol
Now correct me if i wrong, do i want to remove the 2 14mm allan bolts on the back of the block and run those lines to the 2 on the top of the catch can. If i close the drain back valve, will all that crap that is collected just breath out to the atmosphere? If i wanted to run the drain back, just Tee the line back to one of the bolts on the back of the block. Like picture below. i dont want to tap the block for a catch can setup as it is all assembled. there are so many setups and its confusing the hell out of me!!! I should of bought a turboed gsr and call it a day...buy noooooooooo, i had to do a b20v setup
End result should be amazing
Point me the right way
Thanks
Thanks
