Wagon transmission problems?
Hello Honda world.
So I have have a 1989 Civic Wagon 2wd 5speed. Not to long ago it died on me. At least it doesn't drive anymore. The engine still starts up and runs fine. What happened was I started to take a left hand turn from a complete stop. About halfway through the turn there was this loud popping noise and the transmission was ejected out of 1st gear. I tried to go for second, but nothing, same with all of the gears.
A few odd notes. I can slip the transmission into any gear with out needing the clutch, but when it is in gear it engages with the speed sensor and if I rev the engine the speedometer climbs. Recently I did replace the drive shafts on both sides. I have no idea what the problem is and could really use anyones thoughts.
Thanks a ton.
Thanks a ton.
your alex or cv joint could have popped off or out of itself which sends all the power to the broken shaft thats disconects...and thus your tach reads MPH/kilos
mdwood2
Jul 8, 2012 03:13 PM
Mario.
18
Dec 16, 2004 11:21 AM
