Honda S2000 Honda S2000
Having some common problems I think
Old Feb 18, 2010 | 01:55 PM
doubledeucehatch's Avatar
Default Having some common problems I think
Anyone else having these problems with there AP1
1. Starter sticks making a grinding noise on cold mornings.
2. Soft top wear's out farely fast from the bar directly above your head when your sitting in the car.
3. Tires wear out quickly 15,000 miles or so.
4. Sometimes clutch slips at redline.
Just trying to get some good answers about people with the same problem and if they've been able to fix there's yet.
Don't think I'll be able to do anything about the tire wear but you catch th drift.
Thanks in Advance.
Old Feb 18, 2010 | 02:48 PM
HondaKyle's Avatar
Default Re: Having some common problems I think
1) starter has made the grinding sound but that was cuz of problems with AEM EMS
2) nope
3) no idea
4) you need a new clutch
Old Feb 18, 2010 | 03:14 PM
Thanks, I'm asking because I've talked to a couple people with the same problems I'm really concerned with the soft top because I think it can be fixed but not so easily as the starter I just don't want to go thru a convertable top every year.
Well anyone with the same problems?
Old Feb 18, 2010 | 03:21 PM
Boots's Avatar
i havent had any of those problems except replacing my soft top...and my car has 83k on her
Old Feb 18, 2010 | 03:23 PM
Hmmm maybe not as common as I thought. Did your top rip on both sides?
Old Feb 18, 2010 | 03:32 PM
Boots's Avatar
started to...im too picky, i had to replace the top stat
Old Feb 18, 2010 | 04:25 PM
The Black Pearl's Avatar
replace the soft top. and when you do cut patches out of your old top and glue it onto wear areas on your new one :D
Old Feb 18, 2010 | 04:40 PM
Targa250R's Avatar
be professional
It's a RWD sports car with aggressive alignment specs and stagger-sized sticky summer tires. Short tread life is to be expected.
Assuming you're not the average toolbag driver, the clutch is on its way out. Put some money aside now so that when it starts to slip constantly, you'll be prepared to replace it.
Old Feb 18, 2010 | 05:05 PM
HondaKyle's Avatar
I had that problem at 50K miles. I still do because Im to lazy to have my top put on.
Old Feb 18, 2010 | 06:20 PM
SirStig's Avatar
Mine ripped on the driver side as well. It folds right there when putting it up and down so creasing it makes it a high fail spot. Sucks. Had such little wind noise prior to that. Tires go at around there. Quicker for me as I drift on them too... but ya I heard it is common to go through two sets of rears for each set of fronts. Didn't really believe them at the time but I am well on my way towards it.
Old Feb 18, 2010 | 06:52 PM
JDMF22B's Avatar
There was a TSB about the 2nd bar I believe on the soft top.
http://www.allworldauto.com/tsbs/hon...21-7527-1.html
http://www.s2ki.com/forums/index.php?showtopic=275180
http://www.s2ki.com/forums/index.php?showforum=145
I'm not sure if the TSB's in these links overlap, but theres some links to check out. The second link is a safety recall on the tops for 00-02. However I'm not sure if that's relevant. You can skim through them though and see, because I'm pretty sure I remember there being something about the exact bar you were talking about.
Old Feb 19, 2010 | 07:27 AM
Thanks for everyone's help. Looks like the did replace the tops for a seat belt recall. It would be nice if they still would do that.
http://www.allworldauto.com/recalls/...all_41111.html
Old Feb 19, 2010 | 07:30 AM
Yeah well i just drive mine and they go that quick. But IDK with my civic I was always swapping out the gauge cluster and never really new how long my tires lasted. I buy proxes 4's cause the affordably and I like them.
Old Feb 19, 2010 | 09:09 AM
JDogg's Avatar
the clutch will slip when vtec comes in before it will slip at redline.
Old Feb 19, 2010 | 10:21 AM
Sorry should have been more clear i did say it slips at redline I meant to say it slips after you shift at redline. Like red line it in 1st and when you shift in second it will slip its not horrible but you can tell it's slipping.
Old Feb 19, 2010 | 10:31 AM
JDogg's Avatar
ah, that make more since. if its doing that then it will soon start slipping in the midrange. mine started that around 85k miles. i couldnt feel it slipping when vtec hit, but you could see it on the dyno.
Old Feb 19, 2010 | 01:45 PM
Ahhh! maybe I had a tech put a wheel bearing in it the other day he said vtec felt a little weaker than he remembered plus mine has 126,000 on it so it's prolly time for Competition clutch and flywheel.
thtguybryan
Nov 1, 2007 03:21 PM
niq426
Jun 11, 2005 06:39 PM
heeltoer
Jan 4, 2005 07:11 AM
Sprockets
Jul 25, 2003 05:15 PM
GSR1ner
Mar 13, 2002 06:10 AM
